Einstein velocity addition solving for v
The discussion focuses on solving the Einstein velocity addition formula, specifically finding v in terms of u and w. The formula presented is w = (u + v) / (1 + uv), leading to the rearrangement v = (w - u) / (1 - uw). Participants also inquire about the use of LaTeX outside of specialized forums, noting its importance in scientific writing. The conversation highlights the mathematical manipulations necessary to derive the desired variable. Overall, the thread emphasizes the relevance of LaTeX for clarity in scientific communication.
gtguhoij
I am trying to solve for v in the equation below. I just want to confirm I got the correct answer. Can someone confirm? If my writing is to messy I will type it. Just let me know if you can read it?
## w = \frac {u+v} {uv+1}##
It is.
## w = \frac {u+v} {uv+1} = ##
## \frac {w} {u+v} = \frac {1} {uv+1} = ##
## \frac {w} {u} = \frac {1} {(uv+1) -v} = ##
## \frac {w} {u} = \frac {1} {(-uv^2-v)} =##
## \frac {vw} {u} = \frac {v} {(-uv^2-v)} = ##
## \frac {vw} {u} = \frac {-v} {(-uv^2-v)} = ##
## \frac {vw} {u} = \frac {-v} {(-uv^2-v)} ##
## \frac {uvw} {u} = \frac {-vu} {(-uv^2-v)} ##
## \frac {uvw} {u} = \frac {-v} {(-v^2-v)} =##
## \frac {u} {uvw}= \frac {(-v^2-v)} {-v} = ##
## \frac {u} {uvw-v}= {(-v^2-v)} =##
## \frac {-vu} {uvw}= \frac {-v} {(-v^2-v)} =##
## \frac {-u} {uw}= \frac {1} {(v+1)} =##
## \frac {-u} {uw-1}= \frac {1} {(v)} =##
## \frac {-u} {uw-1}= \frac {1} {(v)} =## ## \frac {uw+1} {u} = {(v)} ##
Is there any way to use latex outside the physics forum?
Are you trying to solve for ##v## in terms of ##u## and ##w##? Quicker is:
$$\frac{u + v}{1 + uv} = w \ \Rightarrow \ u + v = w + uvw \ \Rightarrow \ v(1 -uw) = w - u \ \Rightarrow \ v = \frac{w - u}{1 - uw}$$
It's more or less the standard for scientific writing
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
