MHB Elastic Collision of 2 Masses: Calculating \(v'\) and \(V_0'\)
The discussion focuses on calculating the velocities \(v'\) and \(V_0'\) after an elastic collision between two masses, \(M\) and \(m\). The conservation of momentum and kinetic energy equations are presented, leading to the relationships \(MV_0 = MV_0' + mv'\) and \(MV_0^2 = MV_0^{'2} + mv^{'2}\). By manipulating these equations, it is derived that \(V_0 + V_0' = v'\). The participants suggest expressing \(v'\) and \(V_0'\) in terms of the masses and initial velocity \(V_0\). The discussion emphasizes the mathematical approach to solving for the post-collision velocities.
Dustinsfl
We have 2 masses: one with mass \(M\) with velocity \(V_0\) and the other with mass \(m\) and velocity \(0\).
\begin{align}
MV_0 &= MV_0' + mv'\\
M(V_0 - V_0') &= mv'\qquad (*)\\
MV_0^2 &= MV_0^{'2} + mv^{'2}\\
M(V_0 - V_0')(V_0 + V_0') &= mv^{'2}\qquad (**)
\end{align}
So let's take \(\frac{(**)}{(*)}\Rightarrow V_0 + V_0' = v'\)
How do I write \(v'\) and \(V_0'\) in terms of their masses and \(V_0\)?
Mathematics news on Phys.org
\begin{align}
\end{align}
So you could do
\begin{align*}
v'&= \frac{M(V_0-V_0')}{m} \\
V_0+V_0'&= \frac{M(V_0-V_0')}{m}
\end{align*}
Solve for $V_0'$ ...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
