Engineering Elastic Deformation of an Axially Loaded Member
The discussion focuses on the elastic deformation of an axially loaded member, specifically analyzing the forces acting on it. The calculations show that the force in member AB, Fab, is derived as -1.25P, leading to a vertical elongation of -0.0149P. Participants discuss the impact of load P on the dimensions of link AB, which experiences compression and a reduction in length. It is concluded that link AB deforms less than 1 mm, with a specific change in length calculated as 0.8 mm. The conversation emphasizes the relationship between the applied load and the resulting deformation in the structure.
user12323567
Collar A can slide freely along the smooth vertical guide. If the vertical
displacement of the collar is 1 mm and the supporting 20-mm-diameter
rod AB is made of 304 stainless steel (E = 200 GPa), determine the
magnitude of P.
ẟ = FL/AE
Sum of forces in the y-direction = 0 and downwards is +ve
P + Fab,y = 0
P + Fab (4/5) = 0
Fab = -1.25P
ẟ = FL/AE -> ẟab = FabLab/AabE
ẟab = (-1.25P*.75)/(pi*(.01)^2*(200*10^3)) = -0.0149P
After this step, I am uncertain of how I can relate the vertical elongation with AB's elongation to find Force P. Please assist.
Under the action of load P, the shown dimmensions change to be 599 mm vertical and 450 mm horizontal.
Link AB is loaded on compression and its length is reduced some, while its internal stress increases.
Lnewqban said:
Under the action of load P, the shown dimensions change to be 599 mm vertical and 450 mm horizontal.
So, are you saying that the length of the supporting rod, AB would now change to 749.20 mm?
I don’t know exactly by how much (it depends on geometry), but AB becomes shorter under its axial load (which magnitude is greater than P, think mechanical advantage).
Link AB must deform less than 1 mm because the angle it forms with the vertical.
You need to calculate how much force is needed to deform link AB that much; then, you can calculate the value of P.
Please, see:
https://www.engineeringtoolbox.com/young-modulus-d_417.html
A change in length of AB equal to 0.8 mm is correct.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
