ojb89
- 2
A pendulum with a mass m hanging on a elastic bug rigid massless rod which may swing in the xy-plane. The pivot point is the origin of the coordinate system. The force acting on the pendulum is the sum of force of an elastic central force directed towards the origin, and gravity, which by choice of the orientation of the coordinate system, points in the positive y-direction. Friction of any kind (air, in pivot point) can be disregarded.
Newtons's equation of motion:
equation 1: [itex]mx''=-\frac{\partial V}{\partial x}[/itex]
equation 2: [itex]my''=-\frac{\partial V}{\partial y}-mg[/itex]
Gravity: [itex]g=9.81 m/s^2[/itex]
Potential energy of the rod: [itex]V(r)=0.5*k*(r-L)^2[/itex], where [itex]r=\sqrt{x^2+y^2}[/itex]
Length: [itex]L=1 m[/itex] (length of rod in absence of external force)
We see from these equations that the solution does not depend separately on [itex]k[/itex] and [itex]m[/itex], but only the combination [itex]w^2=\frac{k}{m}[/itex].
a)[/B] Here we shall on look at the pendulum moving in vertical direction ([itex]x(t)=0[/itex]). I need to derive the equation of motion in y-direction (in other words I need to show of to get equation 2).
But I'm having problem figure out how I can get it like equation 2. More in attempt of solution.
b) Compute the equilibrium of length [itex]L_r[/itex] for this case.
c) Show that the solution of the equation of motion is an oscillation, up and down about the equilibrium with angular frequency [itex]w[/itex]
a)[/B] So the pendulum will act like a elastic spring with a mass. The two forces acting on the pendulum in each direction. The gravity force which we can write [itex]F_g=mg[/itex]. And the force because of the potential energy which we can write [itex]F_u=-\frac{\partial V}{\partial y}[/itex].
I know we can use Newton's second law: [itex]\sum F=ma[/itex]. And [itex]y''=a[/itex]. But I'm having trouble with the how to set it up. From the problem description I read that [itex]F_g[/itex] is positive and [itex]F_u[/itex] is negative. This gives the the sum of forces [itex]F_g-F_u=my''[/itex]. Inserting gives us: [itex]mg-(-\frac{\partial V}{\partial y})=my''[/itex]. So I get both forces positive, but it should be negative. What am I missing?
b) I know I can find the equilibrium of length by setting [itex]my''[/itex] to 0. So I get [itex]0=-\frac{\partial V}{\partial y}-mg[/itex]. So after I derive [itex]-\frac{\partial V}{\partial y}[/itex], should I solve [itex]0=-\frac{\partial V}{\partial y}-mg[/itex] with respect to [itex]y[/itex] and insert [itex]L=1[/itex] or with the respect to [itex]L[/itex]? Which would give me a solution with something of [itex]y[/itex].
c) I guess I need to solve this as a second order differential equation. With the equation being: itex]y''+0*y'+\frac{\partial V}{\partial y}=0[/itex].
Is this correct? Not sure how to proceed to show the solution.
Sorry for a long post. I really hope I have showed you that I have tried, but I really need help. And not sure if posted in the right sub-forum.
