Elastic Restoring Force- Spring Constant
A bug with a mass of 0.20g causes a spider's web to vibrate at a frequency of 18 Hz, prompting a calculation of the spring constant. The relevant equations include the relationship between frequency, mass, and spring constant. The user initially struggled with the calculation but later clarified the correct approach to find the spring constant using the formula k = 4π²*m*T², ensuring mass is in kilograms. The final calculated spring constant is approximately 2.6 N/m. Understanding the units of the spring constant is crucial for solving similar problems.
~Callaway~
A bug having a mass of 0.20g falls into a spider's web, setting it into vibration with a dominant frequency of 18 Hz. Find the corresponding spring constant.
1. f=\frac{1}{T}
2. \omega=2\pif
3. [natural angular frequency], \omega0=\sqrt{\frac{k}{m}}
4. [natural linear frequency], f0=\frac{1}{2\pi}*\sqrt{\frac{k}{m}}
My thought was to plug the mass in for m and the frequency in for f0 and then solve for k in equation 4, but I am getting an answer very different from the given answer, which is 2.6 N/m. My main question is on the units of the spring constant, I think I am missing just where this unit arises from, and I think I should be able to solve the problem if I can understand that, but I must be missing something. I would very much appreciate any thoughts on this.
Addendum: continued working and solved problem, but here is answer in case anybody else on this forum has a similar problem/issue.
To calculate spring constant from frequency and mass:
Start with equation T=2\pi\sqrt{\frac{m}{k}}
Use algebra to solve for k, k=4\pi<sup>2</sup>*m*T2
Know that T is frequency, so plug in Hz for T and be sure to convert mass to kilograms..
Giving final answer of 2.5582~2.6N/m
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
