MHB Elasticity Business and Economics Applications
The demand function for a product is defined by P=20-0.02x, where P is the price per unit and x is the quantity demanded. Demand is elastic when 0<x<500, unit elastic at x=500, and inelastic for 500<x<1000, with perfectly elastic demand at x=0 and perfectly inelastic at x=1000. Revenue behavior is linked to elasticity; when demand is elastic, revenue increases with price, while it decreases when demand is inelastic. The analysis confirms that marginal revenue is positive in the elastic range, zero at unit elasticity, and negative in the inelastic range.
monster123
Elasticity
The Demand function for a product is modeled by
P=20-0.02x, less than or equal to x less than or equal to 1000
Where p is the price per unit in dollars and x is the number of units.
A. Determine when the demand is elastic, inelastic, and of unit elasticity.
B. Use the result of part (a) to describe the behavior of the revenue function.I started the problem using n=p/x/dp/dx and plugged in the numbers into the formula and did the derivative after computing I end up with an answer of -999 with absolute value of 999 is this correct? if not what could be my mistake?
Mathematics news on Phys.org
According to Wikipedia, the "Point-price elasticity of demand" is given by:
$$E_d=\frac{P}{Q_d}\times\d{Q_d}{P}$$
Here, we have:
$$P=\frac{1000-x}{50}\implies x=1000-50P$$
$$Q_d=x$$
And so we find:
$$E_d=\frac{\dfrac{1000-x}{50}}{x}\times(-50)=1-\frac{1000}{x}$$
A. We have the following:
Demand is elastic: $E_d<-1$
$$1-\frac{1000}{x}<-1$$
$$2-\frac{1000}{x}<0$$
$$\frac{x-500}{x}<0$$
Our critical values are:
$$x\in\{0,500\}$$
We then find the inequality is true on the interval:
$$(0,500)$$
Next, we have:
Demand is relatively inelastic:
$$-1<E_d<0$$
What do you get when solving this inequality?
To follow up, first I want to point out that it is said the price elasticity of demand for a good is perfectly elastic when:
$$E_d=-\infty$$
And we see that:
$$\lim_{x\to0^{+}}E_d=-\infty$$
Okay, back to the case of relative inelasticity:
$$-1<1-\frac{1000}{x}<0$$
$$-2<-\frac{1000}{x}<-1$$
$$2>\frac{1000}{x}>1$$
$$\frac{1}{2}<\frac{x}{1000}<1$$
$$500<x<1000$$
So, the elasticity of demand is relatively inelastic on:
$(500,1000)$
Perfectly inelastic:
$$E_d=0$$
$$1-\frac{1000}{x}=0$$
$$x=1000$$
Unit elasticity:
$$E_d=-1$$
$$1-\frac{1000}{x}=-1$$
$$x=500$$
Let's summarize our findings in the following table:
[table="width: 400, class: grid, align: left"]
[tr]
[td]
Elasticity type
[/td]
[td]
Quantity demanded
[/td]
[/tr]
[tr]
[td]Perfectly elastic[/td]
[td]
$x=0$​
[/td]
[/tr]
[tr]
[td]Relatively elastic[/td]
[td]
$0<x<500$​
[/td]
[/tr]
[tr]
[td]Unitary elastic[/td]
[td]
$x=500$​
[/td]
[/tr]
[tr]
[td]Relatively inelastic[/td]
[td]
$500<x<1000$​
[/td]
[/tr]
[tr]
[td]Perfectly inelastic[/td]
[td]
$x=1000$​
[/td]
[/tr]
[/table]​
Now, to see the effect on revenue $R$, we have:
$$R'=P\left(1+\frac{1}{E_d}\right)$$
$$R'(x)=\frac{1000-x}{50}\left(1+\frac{x}{x-1000}\right)=\frac{1000-x}{50}-\frac{x}{50}=\frac{500-x}{25}$$
On a graph with both a demand curve and a marginal revenue curve, demand will be elastic at all quantities where marginal revenue is positive. Demand is unit elastic at the quantity where marginal revenue is zero. Demand is inelastic at every quantity where marginal revenue is negative.
We have:
$$R'(x)>0$$ for $0\le x<500$
$$R'(x)=0$$ for $x=500$
$$R'(x)<0$$ for $500<x\le1000$
This agrees with our table. When demand is elastic, revenue moves with the price, that is, as price increases, so does revenue, and as price decreases so does revenue. When demand is inelastic, revenue moves against price, that is, as price increases revenue decreases, and as price decreases, revenue increases.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
