Electric currents and Magnetic fields
The discussion centers on the effects of a current-carrying wire on a neutral copper rod, a polarized insulator rod, and a bar magnet. It is established that the magnetic field generated by the current will cause the bar magnet to align with it, while the neutral copper rod and polarized insulator rod will remain stationary. The polarized insulator rod is influenced by the current, but the neutral copper rod does not experience movement due to the magnetic field. There is uncertainty regarding whether the electric field of the current affects the copper rod's polarization. The conversation also touches on the concept of diamagnetism and the relationship between current and polarization.
SDTK
A Neutral copper Rod, a polarized insulator rod, and a bar magnet are arranged around a current-carrying wire.
Will the neutral copper rod, polarized insulator, and magnet remain stationary?
does the electric field of the current carrying wire have an effect on the neutral copper rod? ie will it become polarized?
(The N pole of the bar magnet is arranged so that it oriented toward the current carrying wire.) The bar magnet will rotate so that the N pole aligns with the direction of the magnetic field.
The magnetic field does not effect (cause movement of) the neutral copper rod, or the polarized insulator rod.
The insulator rod is polarized because of the current in the wire. --- I do not believe that it will not move, ... unless the the copper rod becomes polarized... my uncertainty of how the Electric Field of the current carrying wire affects the neutral copper rod is the basis of my question--
Did you mean magnetic field? There is an electric field inside the current-carrying wire, but all it does is push electrons from one end to the other. I believe this question is about the effects of the magnetic field set up by the current in the wire.
Check out "diamagnetism".
Are you saying that if the current is turned off the insulator will stop being polarized? What relevant equation relates the polarization to the current?
Likes SDTK
:-) thank you, for both the comments regarding the question, and the suggestion to check out diamagnetism.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
