Electric field across a parallel plate capacitor
The electric field across a parallel plate capacitor can be described by two formulas depending on the circuit configuration. In a series circuit with a resistor, the electric field is given by E = (V - IR)/L while the capacitor is charging; once fully charged, it simplifies to E = V/L. If the resistor is in parallel with the capacitor, the electric field remains constant at E = V/L throughout. The key distinction lies in whether the resistor is in series or parallel with the capacitor, affecting the potential difference across it. Understanding these configurations is crucial for accurately calculating the electric field in capacitor circuits.
johnj7
Hello,
If I had a potential source (V) , a resistor R, and a parallel plate capacitor,
would the Electric field across the capacitor become
E = (V - IR)/L
L = distance between capacitor
or would the electric field simply become E = V/L
thank you!
How is the circuit set up? Your E = (V - IR)/L would be correct for a purely series circuit. But the current would be zero (or quickly become zero as the capacitor charges) so your second formula is then correct.
johnj7 said:
Hello,
E = (V - IR)/L
That very much depends on whether the resistor is in series or in || with the capacitor doesn't it?
Ah ic, oh okay I understand now.
so if in series,
clearly initially it is
E = (V-IR) /L
but after the capacitor is fully charged then E = V/L
however if in parallel from the start then
E = V/L, always
would this be correct?
If the V, R and C are all in parallel then they all have the same potential V.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
