Electric field and electrolytes
An electric field applied to a solution of sodium chloride in water will experience screening effects due to the ions, leading to a reduction in the field strength. The relative permittivity of water, approximately 80 at room temperature, indicates that the electric field is significantly diminished as polar water molecules align with the field. When voltage is applied to plates immersed in water, the field behaves similarly to that in a vacuum, as the presence of water increases charge accumulation on the plates. Temperature affects the permittivity of water, with higher temperatures reducing the alignment of water molecules with the electric field. Adding salt alters the behavior of water molecules near the ions, further impacting the overall alignment with the external electric field.
Gavroy
Let me assume, that I have an arbitrary electric field. Is there any way to determine what happens to this electric field if it is appolied to a charge in let me say water with natrium chloride in it? I guess there is some kind of response to the electric field by the ions, so that it will just "die out", as the electrolytes will screen it. Is there an equation that would confirm this idea?
It seems that the response of the water molecules is more important than that of the ions.
The relative permittivity of water at room temperature is about 80, this means that if you place a charge near or in water, the electric field will be reduced by a factor of 80 because the polar water molecules line up with the field.
If you put a voltage on 2 plates in the water (low enough so you won't get electrolysis) the field will be the same for water as for vacuum or air, because you get 80 times more charges on the plates immersed in water, until the field strength is equal to a vacuum capacitor.
The permittivity of water depends on temperature. If the temperature is higher, the faster movement of the water molecules will make it harder to align with the field.
Now if you add some salt, this will cause water molecules close to the ions to align with the field with the ions, and this will decrease the alignment with the external field.
this is described here http://arxiv.org/abs/1208.5169
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
