Electric field at a point on the perpendicular bisector of a finite line charge
The discussion focuses on calculating the electric field at a point on the perpendicular bisector of a finite line charge with a linear charge density of 5.00 nC/m. The point of interest is located at (5, 12) in the xy-plane, and the electric field is derived using integration of the contributions from each infinitesimal charge segment along the line. The symmetry of the problem indicates that the x-component of the electric field cancels out, leaving only the y-component to be considered. Participants discuss the importance of correctly expressing the distance and angle in terms of the variable x, emphasizing that both r and θ change as x varies. Ultimately, the correct approach leads to the conclusion that the total electric field at the point is 2.46 N/C.
debeloglava
A uniform line charge of linear charge density \lambda = 5.00 nC/m extends from x = 0 to x = 10m. The magnitude of the electric field at the point y = 12m on the perpendicular bisector of the finite line charge is?
E = \intdE = \intk(dq) / r2
Ex = \intk(dq)cos\theta / r2
Ey = \intk(dq)sin\theta / r2
dq = \lambda(dx)
The perpendicular bisector of the finite line charge occurs at x =5m. I have placed a point (P) at the coordinates on the xy plane at P = (5, 12). With P at this point, the radius from (0, 0) to P is:
r = \sqrt{(5^2) + (12^2)} = \sqrt{169} = 13
If 'b' is the side of the Pythagorean triple equal to 12m then sin\theta = b / r = 12 / 13
With point P bisecting the finite line charge along the x-axis from 0 to 10m I'm arguing by symmetry that Ex = 0, thus there is only a y-component to the electric field.
I'm new to LaTeX and the forums and can't quite seem to get the integration limits to appear properly so the integral is from 0 to 5.
Ey = \intk(\lambdadx) / r2
Ey = \intk(\lambdadx)(12/13) / (132)
Ey = k\lambda(12/13) / (13<sup>2</sup>) *\intdx
Ey = 12k\lambda / (133) * [5 - 0]
Ey = (9 x 109)(5 x 10-9)(12 * 5) / (133)
Ey = 1.23 N/C
Using the idea of symmetry again, E = 2 * Ey
E = 2 * (1.23 N/C)
E = 2.46 N/C
Is my work/thought process and ultimately answer correct?
You're getting there, but remember that both r and θ change as x varies. You can't just use their values for when x=0.
So I shouldn't compute a value for sin\theta and instead leave it in terms of b and r (sin\theta = b / r = 12 / r)?
Then I have (integral from x=0 to x=5 again):
Ey = \int k(dq)sin\theta / r3
Ey = 12k\lambda / r3 * \intdx
Ey = 60k\lambda / r3
Then E = 2 * Ey
E = 120k\lambda / r3
I feel like I'm missing something here...
Let's back up a bit. Say you're looking at the segment of charge between x and x+dx. What is its distance r to the point (5,12) and what is sin θ?
I'm not sure what you mean by "segment of charge between x and x+dx". Do you mean a segment of charge, say at x = 3m?
This new side to the triangle formed by points (3, 0), (5, 0), and (5, 12) would then be a = 5 - x where x is any value along the x-axis from 0 to 5.
I'm using theta to be the angle between the x-axis and the hypotenuse of this triangle. Wouldn't sin \theta remain to be 12 / r? Should I be using cosine instead?
There's zero charge at x=3 m because a point has zero size. The interval [x, x+dx], on the other hand, has a length dx, which, while infinitesimally small, is not 0. This is what you're doing when you write dq=λ dx.
Yes, so you need an expression for r, which will depend on x. Since it depends on x, you won't be able to just pull it out of the integral like you did in your previous attempts.
Sorry, you had already gotten sin θ correctly. I missed it when I looked over your posts too quickly.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
