MarcusK
- 8
So I understand that when an electric field is produced in a conductor of length L, the net electric field in the conductor will be 0 because the rearrangement of electrons in the conductor results in the production of its own electric field which cancels out the one produced initially.
However, when a conductor is connected along to opposite ends of the battery (to the positive and negative terminal respectively), the battery pumps the electrons accumulated at the boundary of the conductor from the positive to the negative terminal through its interior. Then the field inside will no longer be 0 and electrons will continue accelerating towards the positive terminal of the battery.
But this seems to contradict with the set up of a common circuit, where a wire made of conducting material, that is assumed to be ideal and whose resistance is 0 ohms, is connected to a battery (DC source) and a resistor. Technically, in an ideal conducting wire there should be no potential difference along 2 points of a wire as electrons can freely move towards the resistor and thus the potential of a charge before being driven through a resistor should be the same as the emf of the battery. And since there's no potential difference, there would be no electric field. But a battery should produce an electric field as mentioned earlier, which is confusing...
