Electric field of a dipole, two different equations?
The discussion centers on the two different equations for the electric field of a dipole. The first equation presented is E = k p [2cos θ r + sin θ θ]/(r^3), while the second is E = k[3(p·r) r - p]/(r^3). Participants explore how to convert the first equation into the second, suggesting that using the relationship between unit vectors and trigonometric terms may be key. A geometric relationship is highlighted, showing that z can be expressed in terms of r and θ, facilitating the conversion. Understanding these equations is crucial for accurately describing the electric field generated by dipoles.
gareth182
Electric field of a dipole, two different equations??
Hi,
I've been taught in uni how to derive the electric field of a dipole to be
E= k p [2cos theta r(hat) + sin theta theta(hat)]/(r^3)
where k=1/(4pi e0), p=qd= dipole moment, (hat) terms are unit vectors and r is the distance between the halfway point of the dipole and the point of observation.
However, on most internet pages the electric field is expressed as
E= k[3(p.r(hat))r(hat) - p]/(r^3)
can anyone help me convert the first electric field equation to the second?
I'm guessing it may involve using r(hat)=r/r to convert the trigonometric terms back to dot products...
Sorry, I've got to use underlines instead of hats to denote unit vectors. The two expressions you have are
(1) E = kp[2 cos θ r + sin θ θ]/r3 and
(2) E = kp[3 (z·r) r - z]/r3 = kp[3 cos θ r - z]/r3
Geometry tells us that z = cos θ r - sin θ θ, so plug that in (2) and you get (1).
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
