Electric Field of a Uniformly Charged Ring
To find the electric field on the axis of a uniformly charged ring with a radius of 8.1 cm and a total charge of 118 micro Coulombs, the problem requires calculating the field at a point 1.15 cm from the center. The approach involves integrating the contributions from each part of the ring, focusing on the vertical component of the electric field. The integration limits are defined in cylindrical coordinates, with the radius fixed at 8.1 cm and the angle spanning from 0 to 2π. Since the charge is uniformly distributed, the explicit integration can be simplified by deriving the electric field component from a point charge and adjusting for the linear charge density. The final calculation yields the electric field in units of N/C.
ILoveCollege
A uniformly charged ring of radius 8.1 cm has a total charge of 118 micro Coulombs. The value of the Coulomb constant is 8.98755e9 N M^2/C^2. Find the magnitude of the electric field on the axis of the ring at 1.15 cm from the center of the ring. Answer in units of N/C.
F= k Qq/ r^2
E= kq/r^2
I tried subtracting 1.15 cm from 8.1 cm for "r" and plugged that "r" value in the F equation but that answer is wrong. By axis , do they mean horizontally (as in along the diameter) or vertically?
The ring axis is vertical (normal to the diameter).
You should sum the fields produced by each part of the ring (it's an integral over the ring).
Why would I need to integrate? It already gives me the total charge for the ring. from what points would I integrate? 0 to 8.1?
You need to integrate only over the charged area. In cylindrical coordinates it is
<br /> \begin{array}{l}<br /> r = 8.1 \text{cm}; \\<br /> 0 &lt; \phi &lt; 2\pi; \\<br /> z = 0.<br /> \end{array}<br />
Since the ring is charged uniformly there is no need to calculte the integral explicitly.
Just derive the Ez component of the field produced by a point charge placed on the ring. Than multiple it by the factor determined by the linear charge density of the ring.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
