Electric field of point along the central vertical axis of a triangle
The discussion focuses on solving the electric field of a point along the central vertical axis of a triangle. The user presents their calculations for parts (a) and (b), deriving the electric field and the motion of a charged particle under the influence of that field. Feedback emphasizes the need to express equations in terms of a single variable and to clarify notation, particularly distinguishing between constants and variables. Additionally, it highlights the instability of the system and suggests using energy conservation for further analysis. The user is encouraged to include the problem statement in the main post for better assistance.
Samir_Khalilullah
Please see attachments.
## E = \frac {k q} {r^2} ##
## F= Eq ##
## \ddot x + \omega^2 x = 0 ##
here is my attempted solution.
## d^2 = z^2 + \frac {L^2} {3} ##
## C ## is coulomb constant
since the point is symmetric, only the vertical component of the electric field remains. So,
$$ E = 3 E_y =3 \frac {C Q cos \theta} {d^2} $$
$$ E= 3 \frac {C Q z} {d^3} $$
thus part (a) is done ( i think).
for part (b),
the particle with mass ## m ## and charge ## -q ## is experiencing a force
$$ F = -Eq = \frac {-3 C Q q z} {d^3} $$
$$ m \ddot z + \frac {3 C Q q z} {d^3} = 0 $$
$$ \ddot z + \frac {3 C Q q z} {m d^3} = 0 $$
Comparing it with the SHM equation ,
$$ \omega^2 = \frac {k_{spring}} {m} = \frac {3 C Q q } {m d^3} $$
now we know,
$$ K_{energy} = \frac {1} {2} k_{spring} x^2$$
thus we get ,
$$ x = \sqrt{\frac {2K_{energy} d^3} {3 C Q q} } $$
Did i do it correctly??
If i did then im going to approach part (c)
People will be more likely to make an effort to help you if you made an effort to put the statement of the problem where it belongs, in the template instead of in attachments.
sorry ... Should i post a new thread on this with the statement on the template?
Samir_Khalilullah said:
Homework Statement: Please see attachments.
For information, note that the question states that the reduced Planck constant (##\hbar##) is ##6.62 \times 10^{-34}## Js. That is wrong because ##\hbar = \frac h{2\pi}## and ##h=6.63 \times 10^{-34}## Js (not even ##6.62 \times 10^{-34}## Js). However the Planck constant is not required in the question!!!
It may also be worth noting that system described is unstable (c.f. a sharp pencil balanced on its tip). The negative charge will be attracted to one of the positive charges unless it is constrained to the symmetry-axis. (As explained by Earnshaw’s theorem if you want to look it up.)
I'd stick to ##k##. It is distinguishable from ##K## and (if needed) from ##k_{spring}##.
Both ##z## and ##d## are variables. You've already said ##d^2 = z^2 + \frac {L^2} {3}##. Your equation for ##E## should be in terms of the single variable ##z##.
for part (b),
The equation for SHM needs to be in terms of a single variable, ##z##. An equation for ##\omega## should be in terms of constants, but ##d## is not a constant'
You need a differential equation with a single variable (##z##), not both ##z## and ##d##. The equation may be a little messy but when you consider small values of ##z##, you should be able to make an approximation to simplify the equation to the 'standard' SHM equation.
An alternative approach might be to consider energy conservation.
You are asked for a value of ##z##, not '##x##'. And the question refers to this value as 'D'. So your final equation should start 'D =', not 'x ='.
Likes Samir_Khalilullah
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
