Electric Field value at distances from charge or plate.
To determine the Electric Field (E) value at distances from a single charge, the formula E = Kq/r^2 is applicable, where K is Coulomb's Constant. For a charged plate, the surface area does influence the electric field, especially when considering it as a capacitor with positive and negative plates. The electric field between two plates can be calculated, and the electrostatic force on a charge placed between them can be found using F = k(q1)(q2)/r^2, where q1 is the plate charge and q2 is the individual charge. Understanding these equations is crucial for solving problems related to electric fields and forces in electrostatics. The discussion emphasizes the importance of these formulas in analyzing electric fields from both point charges and charged plates.
Blaze3742
If given a single charge (q), how would one determine the Electric Field (E) value at given distances?
How about from a plate? Would the given surface area play apart here?
F=K(q1)(q2)/r^2, K= Coulomb's Constant = 9e^9 Nm^2/C^2, F=Eq, PE=qV, V=Ed
Possibly E=Kq/r^2 for the single charge? Still working on the capacitor.
Yes, E=kq/r^2 for a single charge. Where does it say that the plate is a capacitor?
Two plates are esentially a capacitor. Top plate Posotive and the Bottom plate Negative. Is there an equation to determine the Electric Field value (E,volts) at points between the plates? And what if a specific charge were placed at those points. Is there an equation to determine Electrostatic Force? Or would we just use F=k(q1)(q2)/r^2 with q1 being the plate charge and q2 being the individual charge?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
