Electric field with dielectric
The discussion revolves around calculating the electric field along the axis of a charged ring in a dielectric medium. The participants clarify that the electric field can be computed using the formula involving linear charge density, even when it includes both free and polarization charges. It is established that the presence of the dielectric reduces the electric field by a factor of the relative permittivity εr. The symmetry of the ring means that only the y-component of the electric field needs to be considered, as the x-components cancel out. Overall, the approach to integrating the contributions from the ring's charge is confirmed to be valid despite uncertainties about the dielectric's coefficient.
chrishans
There's a ring of radius R with linear uniform charge density \lambda=constant (which includes both free charges and polarization charges). The ring is in a dielectric region with \varepsilon_r. I have to find the electric field on any point of the axis of the ring
\vec E=\int \frac{\lambda dl (\vec r - \vec r')}{| \vec r - \vec r' | ^3}
I actually don't know and coulnd't find anywhere if I can calculate the electric field using the above formula when \lambda includes free AND polarization charges.
Is there a coefficient missing in your equation ?
No, that's all I have. Since I'm given a linear density for the ring which includes free and polarization charges, I assume it's a dielectric, but I don't know its coefficient. With that density which includes polarization charges, is it ok to calculate the electric field, like in the formula I wrote before?
Since the ring is submerged in a dielectric region with εr, the Electric field decreases by a factor of εr.
So E' = E/εr, where E is the magnitude of the field without the dielectric, and E' with dielectric.
Now take an infinitely small section on the circumference on the ring, dl. The charge associated is dq=λdl.
The field associated with dq is 1/4piε (dq/r^2). However, since the ring is symmetric, the x-component of the net electric field, which is perpendicular to the axis, cancels out. Now all you need to consider is the y component. The y component of the field is Ey= E'cos(theta), where theta is the angle made between the axis, and the field vector coming from dq. Set "z" as the distance along the axis from the center of the circle. You can find cos(theta) using a relationship between "z" and "R", with the use of pythagorean theorem. Also, when you intergrate with respect to dl, change dl to Rd(theta). Integrate all contributions of dq from 0 to 2pi (because it is a circle) and you should be able to find the electric field anywhere along the axis. I understand that this is a sloppy description, but I hope this help anyways.
It should be fine to calculate it treating it as free charges, because your density does include polarization charges.
Strange. i seem to remember that
\vec E= {1\over 4\pi\epsilon_0}\int \frac{\lambda dl (\vec r - \vec r')}{| \vec r - \vec r' | ^3}in vacuum. In a medium it would be ##{1\over 4\pi\epsilon}## with ##\epsilon=\epsilon_0 \epsilon_r##, but I could be mistaken. So check.
There is nothing in ##\lambda## that has to do with stuff outside the ring. No change in ##\lambda##, whatever ##\epsilon_r##.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
