Electric fields of a hallow ball
The discussion centers on the electric field generated by a hollow glass ball with a negative charge. At location A, which is inside the sphere, the electric field is indeed 0 N/C, as the electric field inside a uniformly charged hollow conductor is zero, regardless of the material being an insulator. At location B, outside the sphere, the electric field is calculated to be approximately 2.14 x 10^6 N/C, which is correct. A hydrogen atom placed at location A would polarize due to the influence of the nearby negative charges, but the assertion that all charges contribute to the electric field at location A is incorrect. Overall, the key points clarify the behavior of electric fields in relation to charged hollow spheres.
Kibbel
A hollow ball of radius 5 cm, made of very thin glass, is rubbed all over with a silk cloth and acquires a negative charge of -9.5e-08 C which is uniformly distributed all over its surface. Location A, shown in the diagram, is inside the sphere, 1 cm from the surface. Location B, shown in the diagram, is outside the sphere, 2 cm from the surface. There are no other charged objects nearby.
Which of the following statements about Eball, the magnitude of the electric field due to the ball, are correct? Select all that apply.
1. At location A Eball is 0 N/C.
2. At location B Eball is 2.14 x10^6 N/C.
3.A hydrogen atom at location A would polarize because it is close to the negative charges on the surface of the sphere.
4.All of the charges on the surface of the sphere contribute to Eball at location A.
(1/4*pi*epsilon)*Q/R^2
So i checked at point B that the it is ~2.14 x10^6 N/C. I thought that inside the sphere the electric field is 0, but its an insulator so that means its not. And I am guessing that all of the charges contribute to Eball at location A?
is that looking correct?
Ill go through my thoughts again for each answer:
1. I do not believe that at point A the E of the ball is 0. (Location A is inside the sphere) This is because in an insulator even though the charge on the outside is uniformly distributed, the A is not in the center.
2. That is correct, the location at B is 2.14, according to the numbers given uptop
3.I believe if you placed a hydrogen atom at location A it would polarize because on an insulator there are not free ions to move around so the electron cloud on the atom would move, polarizing it.
4. Yes I do believe that all of the charges on the surface of the sphere act on the location A inside the sphere. And this is why it is cause to not have a field of 0
so, No, Yes, Yes, no, does anyone know if I'm correct, or at least on the right track?
bumpinnnn
somebody love me please?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
