B Electric flux density and confusion about units
Electric flux density is defined as electric flux per unit area, typically expressed in N/C, but it can also be represented using the formula D = εE, leading to the unit C/m². This creates confusion regarding the dimensional consistency between the two interpretations. The discussion clarifies that if D is termed as flux density, the corresponding flux is that of the displacement field, Φ_D = ∫ D·dS. It is also noted that Φ_D relates to the electric flux Φ_E through the equation Φ_D = εΦ_E. Understanding these relationships helps resolve the unit discrepancies.
sunil36
My general understanding of electric flux density is 'electric flux per unit area'. This gives the SI unit N/C. But According the formula of electric flux density, D=eplison*E, the SI unit is C/m^2. How come the dimension in both cases not matching if both are true?
I think there's some terminological confusion. If you're planning on calling ##\vec D## the flux density then the corresponding flux is the flux of the displacement field, ##\Phi_D=\int \vec D\cdot d\vec S##. That's related to the flux we discussed in your other thread, ##\Phi_E=\int \vec E\cdot d\vec S##, as ##\Phi_D=\varepsilon \Phi_E##. I think that should sort out the units.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
