Electric Heater vs Heat Pump: Efficiency for Heating Water to High Temperatures
In summary, electric heaters and heat pumps differ significantly in their efficiency for heating water to high temperatures. Electric heaters typically provide direct and rapid heating but consume more energy, making them less efficient for larger volumes of water. In contrast, heat pumps utilize ambient heat and can be more energy-efficient, especially in moderate climates, though they may struggle to reach very high temperatures. Overall, the choice between the two depends on specific heating needs, energy costs, and climate conditions, with heat pumps generally offering better efficiency for sustained heating.
ATT55
I want to heat 10kg of water from 20C to 80C-90C with the lowest power consumption.
One option I consider is to use an electric heater and the other option is to use a heat pump.
Are heat pumps common for such an application?
The calculated power consumption of the electric heater is 0.7 kW*hr.
What will the power consumption the heat pump, if the COP is 2?
Is it 0.7/2=0.35 kW*hr?
Your calculation is correct, but....your application as described is not common so it's tough to say if heat pumps are common for it or not. Air to water heat pumps are becoming more common for domestic water heating and distributed hot water space heating. But 80-90C is above the typical limits of such products. 80-90C is in the range for typical hot water space heating, but such systems can be designed for lower.
Likes berkeman and Lnewqban
With the output temperature not constant, constant COP just does not feels realistic.
This thing will be nothing simple.
I interpreted the values as a hypothetical average efficiency and range of acceptable output temperatures.
Welcome to PF.
Not common.
Solar preheating is more likely, but it could be done with a heat pump.
Please tell us what climate do you have? Or identify a nearby city.
If it is raining and just above freezing, a heat pump will be a poor investment. One limitation on a heat pump for heating water is when the heat exchanger freezes. Then, a heating element outside in the heat exchanger is used to melt that ice.
How often will you do that ?
Use radiant solar preheating if possible.
Alternatively, use solar PV, to power the water heater.
I do it constantly, I think solar preheating/PV will be too complicated for my application.
i saw this article: High temperature heat pumps and it seems that are few models who can do it, all with COP of ~3-4. Is it an exotic equipment?
For example:
Friotherm Unitop 22/22
Dürr Thermeco2 HHR1000
Kobelco SGH 120/165
That doesn't match your original post. How often, exactly? Is that 10kg per minute? Hour? Day? And is this for heating or bathing (80C is too hot for bathing...). Or an industrial process?
I wouldn't necessarily say it's exotic, just not common at least in the US. I have seen more in Europe but have no actual experience there.
Likes ATT55
Hmmm. I know that heat pump water heaters are starting to roll out in the US at production rates, but as others have mentioned, they’re lower temperature systems. 80-90*C is awfully hot water.
What’s the use case for this water? Because that may have a very important impact on the efficiency of the system.
If we’re talking about strictly using vapor cycle heat pumps, might be worth looking at a two-stage system? And if in a colder climate, the aforementioned icing problem can be offset by a geothermal loop anywhere there’s a reasonably shallow frost line.
Likes russ_watters, ATT55 and berkeman
FAQ: Electric Heater vs Heat Pump: Efficiency for Heating Water to High Temperatures
What is the main difference in efficiency between electric heaters and heat pumps when heating water to high temperatures?
Electric heaters convert electrical energy directly into heat with nearly 100% efficiency, but they consume a lot of electricity. Heat pumps, on the other hand, transfer heat from the surrounding air or ground to the water, often achieving efficiencies of 300-400% because they use less electrical energy to move heat rather than generate it.
How do operating costs compare between electric heaters and heat pumps for heating water?
Heat pumps generally have lower operating costs compared to electric heaters due to their higher efficiency. Although the initial investment for a heat pump can be higher, the reduced energy consumption typically results in lower utility bills over time, making them more cost-effective in the long run.
Can heat pumps effectively heat water to high temperatures?
Yes, modern heat pumps can effectively heat water to high temperatures, often up to 140°F (60°C) or higher. However, their efficiency may decrease as the required temperature increases, and they might need supplemental heating elements to achieve the highest temperatures.
Are there any environmental benefits to using a heat pump over an electric heater?
Heat pumps are generally more environmentally friendly because they use less electricity and can be powered by renewable energy sources. By transferring heat rather than generating it, they reduce the overall energy consumption and greenhouse gas emissions compared to electric heaters.
What factors should be considered when choosing between an electric heater and a heat pump for heating water?
Key factors to consider include initial cost, installation complexity, energy efficiency, operating costs, required water temperature, and environmental impact. If high efficiency and lower long-term costs are priorities, a heat pump may be the better choice. However, if simplicity and lower upfront costs are more important, an electric heater might be more suitable.
