Electric Lines of Force: Debunking the Myth of Crossed Paths in Physics
Electric lines of force are visual representations of the electric field's direction at a given point and do not cross. If they were to cross, it would imply that the electric field points in multiple directions simultaneously, which is impossible. The concept of electric field lines is a tool for understanding the continuous nature of the electric field in space. Crossing lines would indicate a discontinuity in the field, which contradicts physical principles. Therefore, it is established that electric lines of force never cross.
dumbboy340
Is it true that electric lines of force never cross?If yes,then Why?What Physics say about it?
The lines (which are merely visual aids) represent the direction of the electric field at a point. If lines crossed, then the field would be pointing in multiple directions at once--which cannot happen.
Thanks!
It's important to remember that the field lines don't really exist. The field is continuous throughout space, so you simply cannot have two lines cross because it would mean that there is a discontinuity in the field, which is not physically realizable. IE it can't happen.
Thanks!i got that!
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
