Electric motor with outer rotor
In summary, the individual is looking for a DC motor with the rotor on the exterior, similar to a computer cooling fan or ceiling fan. They are having trouble finding such a motor online and are asking for suggestions. The conversation also mentions AC motors and controllers, and the term "outrunner" motor is suggested as a possible match. However, upon further research, the outrunner motors found do not meet the individual's requirements. The conversation ends with the individual asking for more specific requirements and the other person promising to look into it further.
antonantal
243
I'm trying to find a DC motor with the rotating part on the exterior (the electromagnets and wires attached to the central axis) - something similar to a computer cooling fan or ceiling fan. It must be as powerful as possible for about 2 inches diameter. Any idea where I could find such a thing on the internet?
I'd be amazed if you can find one that even exists, that you would be pretty awsome.
PC cooling fans and ceiling fans are not DC motors. They are AC motors. I know lots of places where you can find a AC motor and controller which will have a DC input to the controller.
When I said "something similar to a computer cooling fan or ceiling fan" I was referring to the mechanical similarity (i.e having the rotor on the exterior).
If you know where I could find such a motor (rotor in the exterior) with DC input please tell me.
The term for what you're looking for is an 'outrunner' motor. Try Googling that and you'll find lots of info.
Hmmm...
Give me a couple of days to sober up and I'll take another shot at it. It would be helpful if you can be more specific as to your requirements. Outrunners are the only things that I can think of, off of the top of my head, that match the originally posted question.
FAQ: Electric motor with outer rotor
What is an electric motor with outer rotor?
An electric motor with outer rotor is a type of electric motor where the rotor (the rotating part of the motor) is located on the outer surface of the motor. This is in contrast to an electric motor with an inner rotor, where the rotor is located inside the motor.
How does an electric motor with outer rotor work?
An electric motor with outer rotor works by using the interaction between a permanent magnet rotor and an electromagnetic stator to generate rotational motion. The outer rotor is connected to the motor's output shaft and rotates as electricity is passed through the stator, creating a magnetic field that interacts with the rotor's magnets to produce rotation.
What are the advantages of an electric motor with outer rotor?
One advantage of an electric motor with outer rotor is its compact and lightweight design, making it suitable for use in small and portable devices. It also has a high power-to-weight ratio, meaning it can produce a lot of power while remaining lightweight. Additionally, the outer rotor design allows for efficient heat dissipation, resulting in improved motor performance and longevity.
What are the applications of an electric motor with outer rotor?
Electric motors with outer rotor are commonly used in various industries, including robotics, aerospace, and automotive. They are also used in household appliances, such as blenders and electric fans, as well as in power tools and electric bicycles. Their compact size and high power output make them ideal for use in applications where space is limited.
How does an electric motor with outer rotor compare to other types of electric motors?
Compared to other types of electric motors, an electric motor with outer rotor has a higher power-to-weight ratio and a more compact design. However, it may have lower efficiency and torque compared to other types of motors. The choice of motor type depends on the specific application and its requirements.
