Electric Potential and Kinetic Energy
The discussion focuses on a physics problem involving two identical point charges and their kinetic energy when released from rest. The user attempts to apply the principle of conservation of energy, specifically the relationship between kinetic energy (KE) and potential energy (PE). There is confusion regarding the calculation, as the user initially considers only one charge instead of both. It is emphasized that the total change in kinetic energy for both charges must be accounted for in the solution. The conversation highlights the importance of correctly applying conservation laws in multi-body systems.
jakey
Two identical +9.5e-6C point charges are initially 3.5 cm from each other. If they are released at the same instant from rest, how fast will each be moving when they are very far from each other? Assume they have identical masses of 1.0mg.
im not sure with this though but i used D(KE) + D(PE) = 0 where D=delta
i used the above equation to solve for v. i kinda considered the problem by taking 1 point charge. however, i can't get the right answer...
What do you mean by that?
There are two point charges. Make sure you consider the total change in KE of both of them.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
