Electric Potential Concept Question
The electric potential at the midpoint between two oppositely charged points is zero due to the symmetry of the system, making it a convenient reference point. This does not imply that there is no potential energy at that point; rather, it indicates that the absolute value of potential is not physically significant. Moving a charge from infinity to this midpoint involves no net work done, as both points can be set to zero potential by convention. The potential at the center must match that at infinity, maintaining the symmetry of the electric field. Overall, the discussion emphasizes the importance of relative potential rather than absolute values in understanding electric potential.
123yt
Why is the electric potential in the middle of two oppositely charged points 0? Does this also mean that there's no potential energy at this point?
Remember that all potentials work by looking at how they vary from place to place-- absolute values at a given place are never of any physical importance. So when we take zero at the center, it's just a convenient convention.
Alright... That's somewhat counter-intuitive for me.
So does that mean that if I move a charge from infinity to the middle of the two opposite charges, no net work would be done?
That is also true-- it means that if we set the potential at infinity to be zero, that's the same convention as setting it to be zero at the center. You can tell that has to be true from the symmetry--if the charges are equal and opposite, what is going to be the sign of the potential at the center, relative to infinity? Which sign could possibly be singled out?
Shouldn't it have the exact same value as the potential at infinity?
Yes, by symmetry-- if it were to deviate from the value at infinity, the deviation would need a sign, and we should be able to reverse that sign by reversing the sign of the charges, but such a reversal is just a left/right reflection.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
