Electric Potential (Conceptual question)
To derive the equation E = Δv/d in electrostatics, it is essential to understand that ΔEp = -ΔEk indicates a relationship between potential energy and kinetic energy. The negative sign reflects the conservation of energy, where an increase in potential energy results in a decrease in kinetic energy. When deriving E = Δv/d, the negative sign is accounted for by recognizing that the change in potential (Δv) is defined as a decrease in energy per unit charge. Therefore, the equation illustrates how electric field strength (E) relates to the change in electric potential over distance. Understanding these relationships is crucial for solving electrostatics problems effectively.
Fizickstudent
To find "E" in an electrostatics problem when you are given the velocities and/or distance, you would use the formula E = Δv/d.
Given the information below to start out with, derive the equation E = Δv/d and explain what happens to the negative signs (where do they go and why) as you continue to derive the equation.
Given information:
ΔEp = -ΔEk
Δv/d = Eki - Ekf
Δv/d = -1/2mvf^2
E = Δv/d
For me to derive this equation any further to the equation E = Δv/d I will have to somehow get rid of that negative, I was just wondering, what happens to that negative?
In the given problem delta v is not the change in velocity, but change in potential . Please go through the definition of electric potential at any point due to a charge.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
