Electric Potential - Conceptual question
The discussion revolves around calculating the distance to a point charge and its magnitude based on given electric field and potential values. The solutions provided indicate a distance of 6 meters and a charge of -2 micro-Coulombs. A key question raised is the visual concept behind determining the charge's negativity when using the electric field equation, E = kq/r^2. It is clarified that the sign of the charge cannot be determined solely from the electric field without knowing its direction, but the negative potential confirms the charge's negativity. Therefore, the negative charge is established as a fact based on the provided potential.
EngineerHead
At a certain distance from a point charge, the magnitude of the electric field is 500 V/m and the electric potential is -3.00 kV. (a) What is the distance to the charge? (b) What is the magnitude of the charge?
a) 6 meters
b) -2 micro-Coulombs
*These are correct, I mention this fact cause I don't want you to have to waste your time checking so.
My question is: for part b, if you solve for Q, the magnitude of charge, from E instead of V (E = kq/r^2), what is the visual concept behind why the charge is negative? Because obviously if you solve from V, you will get a negative 2 uC.
Of course the book asks for magnitude anyway, but the answer key gives the negative sign as well. I want to understand the concept behind it.
You cannot tell the sign of Q just using E, since you were not told the direction of the field.
Thank you, and just to verify - because of the potential given, it is a fact that the charge is negative?
Yes.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
