Electric Potential-finding unknown distance
  • Thread starter Thread starter abspeers
    Electric
A 1.5 x 10^-9 C positive charge is located at the origin, while a -1.5 x 10^-9 C charge is positioned 4.5 m to the right, creating an electric potential of -1.8 V at a distance d from the negative charge. The equation for electric potential, V = k [sum] (q/r), is applied to find d, but the initial setup contained an algebraic error. The corrected equation is -1.8 V = k [1.5 x 10^-9 / (4.5 + d) + (-1.5 x 10^-9 / d)]. The discussion focuses on resolving the algebra to find the correct value of d. The thread emphasizes the importance of accurate equation setup in solving electric potential problems.
abspeers
A 1.5 10-9 C charge is at the origin, and a -1.50 10-9 C charge is 4.5 m to the right on the positive x-axis. The electric potential is -1.8 V at a point on the x-axis that is a distance d to the right of the negative charge. Find d.
V = k [sum] (q/r)
-1.8V = k [(1.5 x 10-9 / 4.5 + x ) + (-1.5 x 10-9 / x )]
Maybe I'm doing the algebra incorrectly, but I continue to get the wrong answer although I think the set-up is correct.
The equation is incorrect, it should be
-1.8V = k [1.5 x 10-9 / (4.5 + x ) + (-1.5 x 10-9 / x )]
Show how do you get x.
ehild
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
