Electric spark between person and another person/thing
  • Thread starter Thread starter ZdMh
    Electric Spark
Electric sparks felt between people or objects can be attributed to static electricity, which is influenced by environmental conditions. In hot, dry climates, such as the one mentioned with 15% humidity, static charge buildup is more pronounced due to reduced moisture in the air. The type of flooring, particularly carpets made from wool or synthetic fibers, can also contribute to increased static electricity. Seasonal variations in humidity are significant factors, often more so than temperature alone. Understanding these elements can help explain why electric discharges occur more frequently in certain environments.
ZdMh
TL;DR Summary
Why an electric spark is happening a lot and much stronger in a new country I recently moved to
Hello All!
You know sometimes you touch another person and you felt an electric spark between both of you, or sometimes with things like the door handle, etc. I moved lately to a hot and dry country where the temperature is around 40-45 Celcius degrees now in August, but since I moved here this electric spark happened a lot and much stronger. Yes, I know maybe I must plug myself into a battery to charge it for free Huh, but really why this is happening and is the reason related to the higher temperature?
Dry air slows down the charge loss, so it is easier to build up large voltages. But, often the culprit is just the surface on which you are walking - some carpets/floor types have tendency to quickly built static charges when you walk on them, it doesn't have anything with geography. Back in early nineties I worked at a company where we were forced into replacing the carpet after we lost some hardware to static charges (and I don't speak about anything really fancy, we killed interfaces between things like printers, computers etc).
Are the floors covered with the same material as before ?
Do you wear the same shoes as before ?
I would expect seasonal variation in humidity to be more important than temperature.
What are the two countries ?
@Borek @Baluncore
I think you both are right. My current country is so dry [15% Humidity], while my old one was humid. Therefore the electric discharge is easlily happening!
But thank you for mentioning the idea of "some carpets/floor types", I didn't know of that before... what types do you mean[have a tendency to quickly built static charges]
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
