I Electrical Analog of Aharonov-Bohm Effect
  • I
  • Thread starter Thread starter LarryS
LarryS
TL;DR Summary
Was original experiment, EXACTLY as specified in the 1959 paper, ever performed successfully?
The original paper for what is now called the Aharonov-Bohm Effect was published in 1959. In this paper they proposed two experiments: One for detecting phase shifts for two electron beams, each passing through regions (inside metal tubes) with constant but differing Electric Potentials. The second for detecting a phase shift for electrons passing through a region of constant Magnetic Vector Potential outside of a solenoid.
Was the first experiment, exactly as specified in the original paper, ever performed successfully?
Thank you in advance.
Likes gentzen and vanhees71
The emphasis of “exactly” is a little problematic. It just predisposes you to reject experiments because of some ridiculously insignificant deviation from an idealized theoretical experiment.
Likes vanhees71 and Vanadium 50
Ok. Makes sense. So, were there any experiments for the electrical analog of the AB Effect that were fairly close to the one in the original paper that were successful?
Likes vanhees71 and Dale
Larry, this turns this into a guesing game. "What about this one?" "Nope, doesn't count as close enough." "What about this one. then?" "Nope, doesn't count as close enough either."
Has the OP found any articles that purport such tests? The electric potential result is somewhat less surprising to most folks I think.
I found one article regarding an experiment that used solid-state technology to confirm the electrical analog of the AB Effect. I will try find it. I found no experiments that even remotely resembled the experiment suggested in the original paper.
Very interesting. Nice question, wish I knew more.
Correction: The article I found was for an experiment using graphene rings. My impression of the experiment was that is was more about electron flow in graphene than about the electrical analog of the AB effect. It did not conclusively confirm the electrical AB Effect.
13K
