Electrical circuits don't flow in a circle?
In summary, the author of this article disagrees with the idea that energy flows from the outlet of a wall socket to the light bulb. He thinks that the current flows back and forth between the two slots and the energy is delivered to the light bulb through the resistance of the filament.
Evil Bunny
241
So I came across http://amasci.com/miscon/eleca.html#circle" on W Beaty's site and it's not sitting well with me.
Here is a quote:
So, when you plug a lamp into a wall socket, you shouldn't imagine that the AC energy is a mysterious invisible entity traveling back and forth inside the wires. Instead you should think of AC energy as a mysterious invisible flow that comes out of the outlet, runs along the outside of both wires of the lampcord, then it dives into the filament of the light bulb.
This doesn't seem right to me. My impression has always been that the charges flow from one of the slots (hot) in the wall socket and return on the other slot (neutral) in the socket. Then the charge flows back from that slot (neutral) to the first slot (hot) in the wall socket... This goes back and forth and repeats itself 60 times a second (here in the US anyway). I have never heard anyone claim that these charges are simultaneously (hot and neutral) leaving the socket at the same time and diving into the filament.
I understand about drift velocity and I get that the wave, or impulse, or whatever you want to call it, is what travels along the wire at near light speed and not any individual electron... that's not what I'm having an issue with.
I just always thought that this wave traveled from one side of the source and to the other side of the source. Never have I heard anyone claim that this wave travels simultaneously out of both sides of the source to plunge into a load... I think this notion will only confuse people.
EDIT: It just occurred to me that he's talking about energy and not current. An important distinction... yet I tend to think it would still cause a great deal of confusion to students if this difference is not heavily stressed. any thoughts?
I agree with you...that analogy is not good at all...even from the energy balance point of view...I mean, what if you have devices in series...how is he going to explain energy flowing to two different lamp and the energy coming from both wires at the same time...where is the energy coming from for the wire between the lamps? from the middle of it? magically?
I think that if you are going to explain something, you need a good analogy or your audience is not ready for such concept...but don't confuse them.
And you are correct, too, in thinking that in AC the electrons are moving back and forth inside the wires.
I personally don't like the phrase "energy flow". It doesn't describe what is happening in the circuit at all. I mean, he is correct in saying that energy doesn't flow back and forth in the wires. That is current. But it is the current and all of the forces and effects involved that causes something to happen. Saying energy is flowing from A to B isn't telling anyone anything.
For AC, alternating current, neither of those is true. What happens is that the electrons in the wire move, very rapidly, back and forth.
Energy indeed flows down the outside of the pair of wires to the filament where it is converted into heat.
The current flows back and forth slowly, not rapidly. The energy delivery (Joules per second) to the filament pulsates at 120 Hz (not 60 Hz like the current) in the US as [tex]P = 169^2 sin^2(2\pi*60t)/R[/tex] Watts where R is the resistance of the hot filament in Ohms.
Hmmmm... Still having a hard time digesting a"flow" of energy is what's taking place here... Electrons are flowing for sure. When they meet a resistance heat is created... Does that mean energy "flowed"?
The current switches direction 120 times a second, with corresponds to 60 hz. The "energy" you refer to is the various forces in the circuit producing work. Energy is not a thing, it cannot flow anywhere. It is a measure of the ability to do work. I see it as similar to Beaty's own example on his site on what current is. As he says, current cannot flow, only charges can. The propagation of forces through the circuit is not the same thing as energy, though it is used like that alot.
Electrical energy is very much a thing. It has a spatial density which can be integrated over space; this energy density gravitates, has inertia, and therefore an equivalent mass. It flows from place to place with the precise flow governed by Maxwell's equations. If that's not a thing, what is?
Not sure what this means. I go by the definition of current, which is the flow of charge. It's common to say that current flows but it's more correct to say that there is a current which is a flow of charge.
When EM energy propagates in free space there is no force. When EM energy propagates along a wire there are forces but they are perpendicular to the motion of the charges so no work is done (no energy is lost/transformed.)
Only when the energy does work on a charge does a force and a parallel motion exist. This doesn't happen in ideal wires which is why they don't heat up. It does happen in resistors where the energy become heat or in a motor where the energy becomes force x distance.
No, that is not electrical energy. It is an electromagnetic field which has mass and can do work. How much work it can accomplish is measured by the term energy.
That is what I'm talking about. Current is a flow of charges. Current itself cannot flow since it is describing something that IS flowing, the charges. Similarly, energy is the capability to do work. It is not flowing anywhere, as it cannot flow.
Energy does not do work on a charge, forces do. Those forces are "created" for lack of a better word by particles and EM waves, not by energy.
Here is some http://amasci.com/miscon/ener1.html"...
Money quote:
The energy in a circuit *IS* the energy of the electromagnetic field. Kinetic energy of charge carriers is incredibly tiny, and it does not enter into explanations of circuitry. Refer to a basic textbook on EM Waves. Energy in a circuit is composed of EM fields. (If electrons had no charge, only then would the energy propagate as electron KE.) But energy in circuits propagates as EM fields.
I agree completely Evil Bunny.
Hi Drakkith, you and I generally seem to agree on the endless debates about energy, but I think you may be taking this a bit too far here. Clearly there is a quantity called an "energy flux" and I am pretty sure that "flux" is a fancy word for flow. So I think talking about energy flowing is probably reasonable.
In fact, I can think of energy flows, mass flows, charge flows. It seems to me that many conserved quantities can be considered to flow.
Dale, I spent about 10 minutes writing and re-writing a response trying to explain my reasons, but I cannot seem to get it down correctly in a way that explains it well. It is very difficult to get my thoughts out of my head and down onto paper, text, or conversation correctly. So frustrating...
I agree with you, I simply think it is inaccurate in a similar way as saying Current flows.
Perhaps the confusion and frustration comes from a slightly faulty analogy? I would think that a better analogy would be between charge and energy, not between current and energy.
After all, both charge and energy are conserved scalars in Newtonian mechanics, while current is a non conserved vector. And in relativity both charge and energy are the timelike components of a vector, while current is the spacelike part.
Energy, Charge, and Current are all different things, so saying one is more or less faulty is kind of meaningless in my opinion. To me its as simple as this: Current is the flow of charges. Energy is the capability to do work. For whatever reason, energy apparently means more than that however. At least to most people. I don't know why. But I'm sure I'm wrong somehow.
Agreed completely. But I don't think that the capacity to do work is permanently stuck in one location, which means it can move, which is all that is meant by "flow."
I agree. Just when discussing something like the operation of a circuit, saying the energy flows here and there doesn't really tell me much.
Related to Electrical circuits don't flow in a circle?
1. What is the meaning of electrical circuits not flowing in a circle?
Electrical circuits don't flow in a circle means that the flow of electricity within a circuit does not follow a circular path. Instead, it follows a closed loop path from the power source, through various components, and back to the power source.
2. Why do electrical circuits not flow in a circle?
Electrical circuits do not flow in a circle because of the principle of conservation of energy. Energy cannot be created or destroyed, only transferred. In a circuit, the energy from the power source is transferred to the components, and then back to the power source. It does not continue in a circular motion.
3. How does the flow of electricity work in an electrical circuit?
The flow of electricity in an electrical circuit is driven by the potential difference, or voltage, between the positive and negative terminals of the power source. This creates a flow of electrons from the negative terminal, through the components, and back to the positive terminal.
4. What is the importance of understanding that electrical circuits don't flow in a circle?
Understanding that electrical circuits do not flow in a circle is important for troubleshooting and designing circuits. It helps to identify any potential issues with the circuit and ensures that the flow of electricity is properly directed to power the desired components.
5. Can electrical circuits ever flow in a circle?
No, electrical circuits cannot flow in a complete circle. While the flow of electricity may seem to be circular within a closed loop, it is actually following a closed loop path from the power source to the components and back. It is not a continuous circular flow.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
