Electrochemistry metallurgy mass calculation
To calculate the minimum mass of carbon needed to reduce 1.00 kg of zinc oxide, the balanced reaction equation is ZnO + C → Zn + CO. The molar masses are essential: carbon (C) is 12.01 g/mol, oxygen (O) is 16 g/mol, and zinc (Zn) is 65.4 g/mol. The reaction involves stoichiometry, requiring mole ratios to determine the necessary mass of carbon. It's noted that while CO is the primary product, CO2 can also be formed, but CO is the more relevant reducing agent in this context. Understanding these concepts is crucial for solving the problem effectively.
ambition218
Calculate the minimum mass of carbon needed to reduce 1.00 kg from sufficient zinc oxide.
I think the equation would be 2 ZnO + C = Zn + CO2
I know the molar mass of C is 12.01, O is 16 and Zn is 65.4
I have been taking Chemisty by distance and nowhere in my text materials can I find how to solve this question.
It is a simple stoichiometry. First, balance your reaction equation - you already have correct reactants and products. Do you know how to read reaction equation?
Good guess on the chemical equation...but this type of reaction is smelting of a metal oxide via a heat furnace, which is done industrially. The products for this reaction is not CO2 but is CO, carbon monoxide. The reaction should look like: ZnO+C>Zn+CO
You need to take mole ratios of what is given...a trick is sometimes if you forget a formula is to use the units given and then play with them to get what you want.
From what I understand CO is still strong enough reducing agent to reduce ZnO, so both products (CO & CO2) are possible.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
