Electromagnatics Disperate Help
  • Thread starter Thread starter Berg
    Electromagnatics
The discussion revolves around difficulties in understanding electric charges and electric fields in AP Physics. The user seeks help with specific problems involving electrostatic forces between conducting spheres and point charges. They express confusion over applying Coulomb's Law and charge distribution when the spheres are connected by a wire. Additionally, they inquire about resources for studying electric fields due to various charge configurations. The conversation highlights the importance of solving equations with two unknowns and emphasizes that textbooks may be more reliable than online resources for foundational concepts.
Berg
Hi i am in ap physics and we just finished the electric charges and electric fields chapter but i am completely clueless. I haven't been keeping up with the problems and haven't been to a lot of classes and now it has come back to haunt me. Any good sites out there or can anyone answer some of my questions about these topics? I don't really get these chapters at all.
For example: 2 indentical conducting spheres, fixed in place, attract each other with an electrostatic force of .108 N when separated 50cm. The spheres are then connected by a thin conducting wire. When the wire is removed, the spheres repel each other with an electorstatic force of .0360 N. What were the initial charges on the spheres? Answer is -1 and 3 mirco columbs but i don't know how to get it.
This is the easiest question out of all of my set and i hope if i can understand this the rest will click 2. Also, any good resources on Electirc field due to point, line, disk, charges? thanks in advance
Assume the charges are Q1 and Q2. Write the equation for the force between two charges (Coulomb's Law).
The effect of connecting the spheres by a wire is that this allows the charges to uniformly ditribute themselves, so that the charges on both spheres will now be equal. Since the total charge (Q1 + Q2) is conserved, each sphere must get half this total.
Now again write the force equation with the new charges.
You have 2 equations in 2 unknowns. Solve to find Q1 and Q2.
As far as study resources, your textbook is often better than most online resources. Nevertheless, I believe there's a thread at the top of this forum, listing useful online resources.
Try googling HyperPhysics, that site should help.
Thx for the help guys, I understand charges and Columbs law but i still don't see how it applys to electric fields :confused: For example:
Two point charges q1= -5q and q2= +2q are separated by distance d. Locate the point (or points) at which the electirc field due to the charges is zeo. Sketch the electric field lines.
I do 2 Field due to point Charges equations and set them equal with each other because they both equal 0 and then can equal each other but the 1/4pieo and d2 cancel out and i just end up with -5q=+2q... ?? hmm i don't get it.
Another one that's been really bothering me is...
In Millikan's experiment, an oil drop of radius 1.64 micro meters and density 0.851g/cm^3 is suspended in chamber C when a downward pointing electric field of 1.92 x10^5 N/C is applied. Find the charge on the drop in terms of e
Errr would this be a point charge?
well i figured out the milken experient but for that other charge one all my charges end up canceling out still i don't quite get it :confused: why can't i set them equal to each other?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
