Electromagnetic field under different perspective
The discussion presents a document analyzing the electromagnetic field from a new perspective, introducing a scalar field A and its spatial gradient F, along with a modified Laplacian operator. It establishes a relationship between this modified Laplacian and the d'Alembert equation, which governs electromagnetic potentials in vacuum. By setting the constant k to -1, the equation simplifies to match the d'Alembert equation, demonstrating mathematical equivalence to classical electromagnetism. The findings suggest that the proposed model can effectively describe electromagnetic phenomena using the parameter k. This approach emphasizes the significance of the speed of light in the propagation of events within differential equations.
Roberto Pavani
TL;DR Summary
A different "interpretation" of the electromagnetic field
google doc document link is: https://drive.google.com/file/d/1b5TgfDGFbx3Y1BcfEV3PRF9maq1hY3Zr/view
Here a little document I'd like to have comments on it
Electromagnetic Field from another perspective
Analogy between the Electromagnetic Field and a Field Defined by the Constant k
Definition of the Field:
We have defined a scalar field A and its spatial gradient F:
F = (∂x A, ∂y A, ∂z A)
and its time derivative:
q = ∂t A.
We introduced a modified Laplacian, defined as:
∇̃2 A = A - k ∂t2 A.
If we impose that A satisfies a modified Laplace-type equation:
∇̃2 A = 0,
we obtain:
A - k ∂t2 A = 0.
Comparison with Electromagnetism
In classical electromagnetism, the electromagnetic potentials ∇̃2 = (φ, Ax, Ay, Az) satisfy the
d'Alembert equation:
□ = 0,
where the d'Alembertian □ is defined as:
□ = - ∂t2. (assuming c = 1)
This equation governs the propagation of electromagnetic potentials in vacuum.
Special Case with k = -1
If we choose k = -1, our equation becomes:
A - (-1) ∂t2 A = 0,
which simplifies to:
A + ∂t2 A = 0.
This is exactly the d'Alembert equation:
□ A = 0.
Since the electromagnetic field satisfies this same equation for the potentials , with k = -1, our
theory becomes mathematically identical to the relativistic description of electromagnetic potentials in
vacuum.
Conclusion
- Our model, parameterized by the constant k, describes a scalar field A with propagation defined by a
- When k = -1, the resulting equation is identical to that of the electromagnetic potentials in
electrodynamics.
- This shows that our formalism with k = -1 exactly matches the relativistic electromagnetic theory for the
potentials .
Short explanation:
The reason why the metric is ( 1, 1, 1, -1) is just because events are propagated by the speed of light and this must be taken into account also in differentials equations.
k reflect a coefficent to take this into account
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
