Electromagnetism: Determining Induced EMF
The discussion focuses on determining the induced EMF in a problem involving electromagnetism. Participants confirm the correctness of calculations for parts a) and b) but seek clarification on part c). The direction of the magnetic field B is essential for solving part c), and there is uncertainty regarding the behavior at t=1 when the radius becomes zero. It is noted that the EMF changes polarity at that moment, indicating a reversal in current direction. Overall, understanding the magnetic field's direction is crucial for accurately determining the induced EMF.
Pi314227
There are 3 parts to the question:
A) Determine the induced EMF as a function of time in a circular loop lying perpendicularly to a constant magnetic field if the radius of the loop decreases by r(t) = 5(1-t).
B) Find out the values of the EMF at t= 0,0.1,0.2,...,0.8 seconds.
C) What will be the direction of the current in the loop at t=0 seconds? At what time will the direction of current get reversed?
1) Closed loop integral of EMF = -1 times the derivative with respect to time of the integral of B.n
2) Change in EMF = -1 times the derivative of B with respect to time
Likes Delta2
Your work for a) and b) looks correct to me.
What about part c? Could you help in that?
For c) i think i have to know the direction of the magnetic field B. Also i am not sure what happens at t=1 since the radius becomes zero then, but yes it looks like the EMF changes sign(polarity) at that point and hence the direction of current is reversed.
Right. The direction of the magnetic field B was not given. Thankyou so much for your help. Appreciate it alot! :)
Likes berkeman and Delta2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
