Electromotive force (EMF) induced in a rectangular loop
The discussion centers on the relationship between electromotive force (EMF) and magnetic flux, referencing Faraday's Law, which states that the induced EMF is proportional to the rate of change of magnetic flux. The formula for induced EMF can be simplified for constant rotation to Emf_{induced} = -N\frac{\Delta \Phi}{\Delta t}. One participant calculated the induced EMF to be 1.708 x 10^{-3} V using this formula. The conversation emphasizes understanding the principles behind the calculations rather than simply providing answers. Overall, the discussion highlights the application of Faraday's Law in practical scenarios.
Fleuryette
A rectangular single loop of wire of length 0.035m and width 0.015m is positioned at 45° to a uniform magnetic field of 2.3T. The loop is rotated through 45° so that its plane is parallel to the magnetic field. Determine the electromotive force (e.m.f.) induced in the loop if the rotation takes 0.5s
emf = BAN cosθ
242410
Hi, so you have calculated the flux \Phi_B = \int \vec B \cdot d\vec A, but what is the relationship between Emf induced and the flux? Have you heard of Faraday's Law, which states that the emf induced is given by Emf_{induced} = -N\frac{d\Phi_{B}}{dt}. If you are assuming that this rotates at a constant speed, then you can change the formula to Emf_{induced} = -N\frac{\Delta \Phi}{\Delta t}.
Hope that is some help. I can answer more questions, but I am trying not to give the answer away.
Hello, thank you for your message! After some thought and looking around in textbooks etc. I believe that by using Emf_{induced} = -N\frac{\Delta \Phi}{\Delta t} I have calculated the Emf to be -1\frac{0 - (8.54\text{ x }10^{-4})}{0.5} = 1.708 \text{ x } 10^{-3} \text{ V}
I hope this is correct?
Thank you
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
