Electron Current/movement in P-N junction under forward bias
  • Thread starter Thread starter MaestroBach
    P-n junction
In a P-N junction under forward bias, the P side primarily conducts hole current, while the electron current at the far end of the P side approaches zero. For the circuit to function, electrons must flow toward the positive side of the applied voltage, necessitating an outflow of electrons from the P side of the junction. This outflow is facilitated by forming a non-rectifying Schottky junction, which connects the semiconductor to the copper conductor. Schottky junctions also eliminate the built-in voltage outside the diode, making it undetectable with a voltmeter when the diode is unpowered. The term "contacts" refers to these junctions that facilitate the connection.
MaestroBach
TL;DR Summary
I've been studying p-n junctions and have noticed that I seem to be not understanding something pretty fundamental regarding holes and electrons in both circuits and in p-n junctions.
For context, I have very little background knowledge of circuits.
I'm reading about P-N junctions under forward and reverse bias, and I'm having a bit of trouble visualizing what's happening where the P side of the junction meets the circuit under forward bias.
From what I understand, at the very end of the P side of the junction, there is only hole current and the electron current goes to 0. But given that for the circuit to actually work, electrons have to flow towards the + side of the applied voltage, wouldn't there need to be a flow of electrons out of the P side of the junction? How would that happen when the electron current inside the diode at the far end of the P side is 0?
Please let me know if I"m being unclear with what I'm trying to ask. Thanks!
In order to connect the semiconductor to the copper conductor you need to form a non rectifying Schottky junction. IIRC these junctions are also responsible for the disappearance of the builtin voltage outside the diode (you can't measure it with a voltmeter attached to a non powered diode).
Ah, would these also be called the "contacts"?
Yes.
Likes MaestroBach
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
