Electron in a parallel plate capacitor
To determine the acceleration of an electron in a parallel plate capacitor, one must apply kinematic equations for both the x and y directions. Newton's Second Law is crucial for relating acceleration to net force, which in this case is the electric force acting on the electron. The electric force can be expressed in terms of the charge of the electron and the electric field strength. Understanding how these equations interconnect is essential for solving the problem. Clarifying the relationship between acceleration, force, and electric field will lead to a complete understanding of the electron's motion.
anyone? thanks.
I believe the posters in the previous thread hinted at the strategy quite nicely, but I suppose I'll detail it a bit more. First note the equations for kinematics. Let's define the vertical direction as our y-direction, and the horizontal direction as our x-direction. What is happening to the electron in the x-direction in terms of force (and subsequently accelertion)? Consider the same for the y-direction. You should be able to use these kinematic equations to find the acceleration of the electron. Then consider Newton's Second Law, and how the acceleration fits into this equation. This will allow you to find the net force, which is an electric force (hint hint). How can you write down the electric force in terms of the charge of the particle and the electric field?
I have the acceleration, but nothing else makes sense after that. Care to explain?
Oh wow, this is quite an old thread. I guess the problem was to find the magnitude of the electric field. If you already have the acceleration of the electron, you're all set. What's the equation for Newton's Second Law? What's the equation for electric force? How do these equations relate to one another in this particular problem?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
