Electron launched at an angle in a parallel plate field.
The discussion revolves around the calculations for an electron launched at an angle in a parallel plate electric field. The user correctly calculated the time of flight and acceleration but struggled with the application of the kinematic equation for vertical motion, specifically misapplying the formula by omitting the 1/2 factor. Participants emphasized the importance of verifying values for charge-to-mass ratio and ensuring all algebra is performed before inputting numerical values. Ultimately, the user acknowledged the mistake in the equation and corrected it, leading to a resolution of the problem. Accurate calculations and attention to detail are crucial in physics problems involving electric fields and motion.
Esoremada
http://puu.sh/6i6HY.png
Fe = q*Ee
a)
dx = vx*t
0.0682 = 4.92*106 * cos(68) * t
t = 0.0682 / [4.92*106 * cos(68)]
= 3.70036*10-8 seconds
dy = dyi + vy*t + at2
0 = 0 + 4.92*106 * [0.0682 / [4.92*106 * cos(68)]] * sin(68) + a * [0.0682 / [4.92*106 * cos(68)]]2
a = -4.92*106 * [0.0682 / [4.92*106 * cos(68)]] * sin(68) / [0.0682 / [4.92*106 * cos(68)]]2
= -1.23278 * 1014 m/s2
mass of electron = 9.10938291 * 10-31 kg
charge of electron = 1.60217657 * 10-19 C
Fe = ma
= 9.10938291 * 10-31 * [ -4.92*106 * [0.0682 / [4.92*106 * cos(68)]] * sin(68) / [0.0682 / [4.92*106 * cos(68)]]2 ]
Ee * q = Fe
Ee * 1.60217657 * 10-19 = 9.10938291 * 10-31 * [ -4.92*106 * [0.0682 / [4.92*106 * cos(68)]] * sin(68) / [0.0682 / [4.92*106 * cos(68)]]2 ]
Ee = 9.10938291 * 10-31 * [ -4.92*106 * [0.0682 / [4.92*106 * cos(68)]] * sin(68) / [0.0682 / [4.92*106 * cos(68)]]2 ] / (1.60217657 * 10-19)I got part b correct, so I must have the correct acceleration - now I can't figure out where I'm going wrong.
Check your reasoning ...
Also: Remember your ballistics?
If you have the acceleration right, then E=a(m/q)
If that gives the wrong E then (a) you have used a bad value for q/m for an electron - maybe a rounding error? or (b) you didn;t get the right acceleration and the correctness of the answer to part b is a fluke.
Best practice is to do all the algebra before putting the numbers in.
Likes 1 person
Fe = q*Ee
a)
d = vt
0.0682 = 4.92*10^6 * cos(68) * t
t = 0.0682 / [4.92*10^6 * cos(68)]
= 3.70036*10^-8
The time of flight is correct if you meant in in seconds.
Esoremada said:
d = di + vt + at^2
0 = 0 + 4.92*10^6 * 3.70036*10^-8 * sin(68) + a * [3.70036*10^-8]^2
a = -4.92*10^6 * 3.70036*10^-8 * sin(68) / [3.70036*10^-8]^2
= -1.23278 * 10^14 m/s^2
Is it the same d as before, when you wrote that d=vt?
The electric field is normal to the capacitor plates. What is the direction of the acceleration? Does the electron accelerate horizontally?
ehild
Likes 1 person
ehild
No I used horizontal velocity and distance to find time, and then used vertical velocity, distance and time to find acceleration. I'll add subscripts to the OP to make that more clear
I took the electron values to many more decimals than the homework system checks (3).
I changed all my calculations to not use any previously calculated values and reformatted the exponents. Do you see any specific incorrect logic or calculation now?
The equation
is wrong. Check.
ehild
Likes 1 person
ehild said:
The equation
is wrong. Check.
ehild
Oh man, messed up that equation after using it hundreds of times. Thank you very much, that fixed it.
(and I forget the 1/2 both times and the mistakes canceled out which is why I got the right answer for part b :rolleyes:)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
