Electrophoretic Mobility of Hydrophobic/Charged Particles in Saline Solutions
In summary, when a hydrophobic/hydrophilic substance with surface charge is dispersed in water and different salts (such as NaCl, NaNO3, and NaSCN) are added, the substance will become more compact with the hydrophobic parts internalized and the hydrophilic parts exposed. This will result in a faster and farther movement of the substance. The order in which the salts are added will determine their strength in affecting the substance's structure and mobility. The stability and interaction of the substance with different salts will also vary depending on its hydrophilic/hydrophobic nature and surface charge.
toni_2374
suppose we have a substance that is hydrophobic/hydrophilic and also has some charge on it surface(negative or positive) disspersed in water. if we add some salt different kinds possible(NaCl NaNO3 NaSCN). What is the effect of hydrophobicity and surface charge on Electrophoretic mobility?
Chemistry news on Phys.org
Salts will cause the substance to adopt a more compact structure with the hydrophobic bits internalized and the hydrophilic bits exposed. It should move faster/farther.
TANX
but i want a explanation for the order of salts, which one acts more strongly?, and what is the difference between hydrophilic/hydrophobic dispersed substance with negetive/positive charge on its surface regarding their stability,how they interact with diffrent salts.
Related to Electrophoretic Mobility of Hydrophobic/Charged Particles in Saline Solutions
What is electrophoretic mobility?
Electrophoretic mobility is a measure of the movement of charged particles in an electric field. It is influenced by the size, charge, and shape of the particles, as well as the properties of the surrounding fluid.
How is electrophoretic mobility measured?
Electrophoretic mobility can be measured using techniques such as capillary electrophoresis or gel electrophoresis. In these methods, an electric field is applied to a solution containing the particles and their movement is observed and measured.
What is the role of saline solutions in electrophoresis?
Saline solutions are commonly used in electrophoresis as they provide the necessary ions for conducting electricity and also help to maintain a stable pH. Additionally, the concentration and type of salt in the solution can affect the electrophoretic mobility of particles.
How do hydrophobic particles behave in saline solutions during electrophoresis?
Hydrophobic particles are typically less mobile in saline solutions compared to hydrophilic particles. This is because the hydrophobic particles tend to aggregate and form larger clusters, making them less responsive to the electric field.
What are some applications of studying electrophoretic mobility of particles in saline solutions?
Electrophoretic mobility in saline solutions has many applications, including protein analysis, DNA sequencing, and drug delivery systems. By understanding the behavior of particles in different conditions, scientists can design more efficient techniques for separating and studying biological molecules and particles.
