Electrospray ionisation
  • Thread starter Thread starter hmparticle9
    High voltage
Electrospray ionization involves dissolving a sample and pushing it through a high-pressure nozzle, where a high voltage is applied. This voltage causes particles to gain a proton (H+), resulting in a gas of positive ions. The high voltage creates charge separation, leading droplets to become charged due to the movement of electrons. Charged droplets can either gain extra electrons or lose them, resulting in a net positive charge.The attachment of H+ ions occurs because some molecules have areas with free electron pairs that can accommodate protons. For example, water molecules can interact with protons, allowing them to bond. However, the introduction of H+ can disrupt molecular stability, potentially leading to decomposition. This process highlights the complexity of charge interactions and molecular behavior in electrospray ionization.
hmparticle9
In my Chemistry book, the following is said:
Electrospray ionisation - the sample is dissolved and pushed through a small nozzle at high pressure. A high voltage is applied to it, causing each particle to gain an ##H^{+}## ion. The sample is turned into a gas made up of positive ions.
I really would like a step by step explanation of the above. How does applying a voltage to the sample cause each particle to gain an ##H^{+}## ion?
Chemistry news on Phys.org
In no way that's my area of expertise, but I don't think it is an accurate description.
Imagine a droplet leaving a nozzle - if the nozzle is at a high voltage, most droplets will be charged. That means they have an extra electron (or several), or they miss an electron (or several). These extra electrons (or non-electrons ;) ) have to be "stored" somewhere in the droplet. Unbalanced H+ are one way of the charged droplet to keep the charge (common one, no doubt about it), but definitely not the only one.
Okay. I am basically a math guy that is trying to get into science.
If the nozzle is at a high voltage, the droplets will be charged. why?
I understand the extra/missing electrons when charged.
How does the ##H^+## "attach" itself to the sample?
Really explain your post like you are trying to explain it to a 5 year old. I am that level.
Physics 101 - basically high voltage always means charge separation (that's how you create a voltage - by moving charges apart, every joule of energy spent to move away a coulomb of charge produces 1 volt). If there is a voltage between two electrodes you can be sure both these electrodes have some extra charge on them. Identical charges repel, so charge carriers will happily jump on leaving droplets.
More like it is somewhere "inside" of the sample.
Some molecules have groups with free electron pairs (water molecule for example, doesn't mean it is charged) which can reasonably easily accommodate a proton (which is what H+ actually is). These are places where an extra positive charge in the form of proton will most likely land. But in many cases these extra charges will disrupt something and will start some kind of decomposition of the molecule.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
