Electrostatic: Electron Transfer & Conductivity
Rubbing two electrically neutral insulators together results in one becoming positively charged and the other negatively charged due to electron transfer. The transfer is influenced by the electron affinities of the materials, but conductivity also plays a role in how charges are managed. A misconception arose regarding the relationship between conductivity and electron affinity, as some high-conductivity materials like gold and silver also possess high electron affinity. The discussion highlights the importance of understanding the distinction between charging by friction and charging by induction or conduction. Overall, further research is encouraged to clarify these concepts and foster better understanding.
Tam Le
If you rub two electrically neutral pieces of insulation together, one piece becomes charged and the other piece becomes oppositely charged.
Does this transfer of electron depend merely on the electron affinities of the two pieces, or does the conductivity of the two insulations play a part?
I imagine a poor insulator (high conductivity) to have a lower electron affinity; it wants to move/get rid of its electrons. Likewise, I imagine a good insulator (low conductivity) to have a higher electron affinity; it wants to hold onto its electrons.
Thank you for replying meBigGuy.
After reading your link and others, I think I cleared the confusion: I thought that since conductors are good at moving charges throughout them, they must also be good at transferring their charges. Hence, I thought that if I rubbed two different, electrically neutral, nonpolarized materials together, the better conducting material would conduct its electrons to the poorer conducting material, thus eliminating the electron affinity explanation. However, I completely forgot to factor in that nonpolarized and electrically neutral part, which would interfere with charge transfer. I basically attempted to explain charging by friction with charging by induction and conduction.
I also thought that electron affinity was somehow inversely proportional to conductivity. But, after not much research, I found that was not the case: Au and Ag, for example, have both high electron affinity and high conductivity.
To conclude, I should have done more research before posting this question; I admit my ignorance :sorry:.
But, feel free to ask about anything in your research that you have a problem understanding. We love getting questions. Demonstrate a little effort and you will get responses from people who like to help. It just that it is very difficult to explain things from the very very beginning.
Likes Tam Le
We're all ignorant, but on different subjects.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
