A Electrostatic interaction inside and outside the source
The discussion focuses on calculating the electrostatic interaction between an electron and a nucleus, considering the electron's potential presence within the nucleus. The user presents a double integral involving the electron and nuclear coordinates and seeks to simplify the expression for the interaction term, specifically the term ##\frac{1}{|r_e-r_n|}##. A suggested approach involves expanding this term using Legendre polynomials, which allows for a clearer representation of the interaction. The expansion can facilitate further simplification and truncation as needed for practical calculations. The conversation emphasizes the mathematical techniques necessary for handling complex integrals in quantum mechanics.
kelly0303
Hello! I want to get the electrostatic interaction (between and electron and a nucleus), while accounting for the fact that the electron can also be inside the nucleus (e.g. in an S##_{1/2}## state). I ended up with this double integral:
$$\int_{r_e=0}^{r_e=\infty}\int_{r_n=0}^{r_n=R}\frac{\rho(r_n)}{|r_e-r_n|}d^3r_ed^3r_n$$
where ##r_e## and ##r_n## are the electron and nuclear coordinates and ##R## is the nuclear radius. Please note that we are not necessarily assuming that the nucleus is a perfect sphere (although it is usually very close to it). How can I expand the ##\frac{1}{|r_e-r_n|}## and get this into a simpler form that I can also truncate as needed? Thank you!
That function is expanded in Legendre polynomials as
$$\frac{1}{|{\bf r}-{\bf r'}|}=\sum_l\frac{r'^l}{r^{l+1}}P_l(\cos\theta)$$,
with the smaller r in the numerator.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
