Electrostatic vs DC Conduction Simulations for E-field Analysis
Electrostatic and DC conduction simulations are both viable for e-field analysis, as their underlying mathematics is similar. Electrostatic simulations are best used when fields are static, while DC conduction is suited for scenarios involving current flow. Changes in dielectric constant impact electrostatic field gradients, whereas conductivity variations affect DC conduction gradients. The choice between the two methods depends on the specific conditions of the simulation. A more detailed question would lead to a more tailored response.
EE4me
TL;DR Summary
When is it appropriate/inappropriate to use electrostatic and dc conduction simulations for e-field analysis
Hi,
I am doing e-field simulations and have came across two types; electrostatic and dc conduction. I know that electrostatic means there is no changing field so I'm just hoping for discussion on when one is more appropriate than the other and when one definitely should or should not be used.
Welcome to PF.
You can use either method for simple field analysis between boundaries because the mathematics is the same for both. One can be adapted to be the analog of the other.
With electrostatic field mapping, changes in dielectric constant will affect the field gradient.
With DC current field mapping, changes in conductivity will affect the field gradient.
For a more specific answer we need a more specific question.
Are you using a physical model or a computer algorithm ?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
