Elementary Corrective Lens Problem
  • Thread starter Thread starter EstimatedEyes
    Elementary Lens
A farsighted woman is using old eyeglasses with a refractive power of 1.655 diopters, which do not fully correct her vision, requiring her to hold a newspaper 39.4 cm away. The object distance (do) is identified as 0.394 m, and the formula 1/f = 1/(do) + 1/(di) is applied to find the image distance (di). The calculated di is 1.13 m, leading to a near point of 1.15 m when accounting for the distance from the eyeglasses to her eyes. A misunderstanding arises regarding the measurement of object distance, which should be from the lens rather than the eyes. Clarifying this variable is crucial for accurate calculations.
EstimatedEyes
A farsighted woman breaks her current eyeglasses and is using an old pair whose refractive power is 1.655 diopters. Since these eyeglasses do not completely correct her vision, she must hold a newspaper 39.4 cm from her eyes in order to read it. She wears the eyeglasses 1.90 cm from her eyes. How far is her near point from her eyes?
di < 0 for virtual images (what this is)
do is .394m and 1/f=1.655 diopters
so 1/(1/.394m - 1.655) = di
di = 1.13m
Near Point = 1.13m + .019m = 1.15m
Where did I go wrong? Thanks!
Hi EsimatedEyes,
do is .394m
What is the variable do? It is called the object distance, but what is it? In particular, what two points is it measured between? Once you answer that, I think you'll see what do needs to equal here.
I just figured out that the distance was from the lens so I kept getting it wrong because I was using the eyes value that they gave.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
