Elementary Question on Relative Density
In summary, when 50g of sulphuric acid with a relative density of 1.84 are mixed with 50g of water, the resulting mixture has a relative density of 1.40. This indicates that the volume of the mixture is 71.429cm^3 per 100cm^3. The contraction in volume is therefore 28.571cm^3 per 100cm^3 of the mixture. However, the initial volume of the dry acid cannot be determined solely based on this information.
John O' Meara
330
50g of sulphuric acid of relative density 1.84 are mixed with 50g of water, and the relative density of the mixture is found to be 1.40. Calculate the contraction in volume which has occured? My attempt follows.
R.D., = density of acid/density of water => density of acid =1.84g/cm^3.
A R.D., of 1.40 => a density rho = 1.40g/cm^3.
100g divided by 1.40g/cm^3 = 71.429cm^3.
The contraction in the volume is 28.571cm^3 per 100cm^3 of the mixture!
What's the initial volume of the dry acid? (It's not 50 cm^3).
I would first like to clarify that the relative density of a substance is a measure of its density compared to the density of water at a specific temperature. In this case, the relative density of sulphuric acid is 1.84, meaning it is 1.84 times denser than water at the same temperature.
Now, to calculate the contraction in volume, we can use the formula for density, which is mass divided by volume. We know that the total mass of the mixture is 100g, with 50g of sulphuric acid and 50g of water. Using the relative density of the mixture, 1.40, we can calculate the volume of the mixture.
Volume = mass/density = 100g/1.40g/cm^3 = 71.429cm^3
However, this is the volume of the mixture as a whole. To find the contraction in volume, we need to subtract the original volume of the acid (50g/1.84g/cm^3 = 27.174cm^3) from the total volume of the mixture.
Contraction in volume = 71.429cm^3 - 27.174cm^3 = 44.255cm^3
Therefore, the contraction in volume is 44.255cm^3 per 100cm^3 of the mixture. This means that for every 100cm^3 of the mixture, there is a decrease in volume of 44.255cm^3 due to the mixing of the acid and water. I hope this explanation helps to clarify the concept of relative density and how to calculate the contraction in volume.
FAQ: Elementary Question on Relative Density
What is relative density?
Relative density, also known as specific gravity, is the ratio of the density of a substance to the density of a reference substance. It is a unitless measure that compares the density of a substance to the density of water at a specific temperature.
How is relative density measured?
Relative density can be measured using a variety of methods, including hydrometers, pycnometers, and electronic density meters. These instruments measure the mass and volume of a substance to determine its relative density.
What is the significance of relative density?
Relative density is important in many scientific fields, including chemistry, physics, and geology. It can be used to identify and classify substances, determine the purity of a substance, and understand the behavior of materials in different environments.
How is relative density different from density?
Density is an absolute measure of how much mass is contained in a given volume of a substance. It is typically expressed in units of mass per unit volume, such as grams per cubic centimeter. Relative density, on the other hand, is a comparison between the density of a substance and the density of a reference substance.
Can relative density change?
Yes, relative density can change depending on the temperature and pressure of the substance being measured. It can also change if the reference substance is changed. However, the density of a substance will remain constant regardless of these factors.
