- #456
subtillioN
Originally posted by Hurkyl
If the theory isn't good enough to stand on its own merit, then it isn't good enough to be a replacement.
Now, that's a bit obvious, don't you think?
I can't believe people aren't harping on this more. How do you know relativity is wrong if you (admittedly) don't understand what relativity means?Originally posted by subtillioN
I do not claim to understand Relativity in its entirety nor nearly as well as you people who need it to "understand" and quantify reality. It is simply superfluous to me, thus I do not need to know its details.
Well, at least we now know your fight or flight response when backed into a corner.Originally posted by subtillioN
You will never know because I am done discussing irrelevantivity.
I submit to you however, that a good scientist when backed into a corner he sees no escape from, doesn't run but stays and figures out HOW and WHY he got into that corner and LEARNS from it where he went wrong.
Yes. And if you strive to be a good scientist, you eventually will.Originally posted by subtillioN
A good scientist is curious about an alternative explanation of reality and not fearfull as has been exhibited so often on this board. That is the only way he can learn where he went wrong.
Originally posted by ofikn
Hello again!
Every time I write that I am _NOT_ trying to attack you, I am trying to get you to change the _FORM_ of your paper to one that could be published.
You claim that there is a problem with the supernovae data, but nowhere in the pdf do you give the numbers, then you claim that your equations solves this discrepancy in the numbers, but you never show that part of the math. I believe you may you have solved that problem, but you do not present this data. Just sending me back for the 5th time to the pdf (which is on my desktop) will not get you published.
A potential title to a publishable paper:
A potential solution to the discrepancy between general relativity and the supernovae recession data.
An abstract:
According to measurements by ... and ... it can be shown that the quantity _____ is ______ where G.R. predicts it to be ... (with references of course) The equation ... derived in this paper shows that this can be repaired with the results of the calculation given as ... with a relative error of ... This set of equations is consistent with other measurements such as the Mossboher (sp) effect etc.
If the numbers check out then this will be published.
Start small, and correct then build up to your final theory.
Have a great weekend! I am off to sunnier climes for a few weeks, so keep up the good work, and maybe try to change just a little. (My shrink told me not to be confrontational you should try it!)
Ofek
