Elephant toothpaste to fight fires?
The discussion centers on a school project aimed at enhancing fire rescue efforts through innovative firefighting techniques. One idea proposed involves creating a transportable device that utilizes a decomposition reaction, specifically referencing "elephant toothpaste," to potentially extinguish fires. However, concerns are raised about the effectiveness of this approach, as the foam produced from the classic elephant toothpaste reaction contains oxygen, which could actually reignite flames rather than extinguish them. Participants suggest exploring alternatives like intumescent paint, which is designed to expand and insulate against fire, and recommend researching its application methods, including the use of airless spray equipment or carbon dioxide as a propellant. The conversation emphasizes the importance of selecting appropriate materials for effective firefighting solutions and highlights existing foam-based extinguishers for flammable liquids.
Occar
TL;DR Summary
decomposition reaction (elephant toothpaste) with fire
So i'm doing a project for school with the local firefighters and we have to help save time to rescue people from a fire.
So i had an idea, What if we made a transportable device that could contain the chemicals and stuff to create a decomposition reaction. I wanted to test my theory that elephant toothpaste could stop fire if it was on top of it. Only i'm not able to due to school restrictions. Can anyone explain to me if this would work and how it would work with the stopping of fires and preventing the spreading of poisonous gas?
Chemistry news on Phys.org
Foams are definitely used in firefighting, but they have to be carefully selected. Think, what is the gas in the elephant toothpaste and how is it related to fire?
Likes Occar, DaveE and Nugatory
You could then consider reactions which generate other, fire quenching gases and look to foam it.
+100 to this.
Try searching intumescent paint. Drill down a little, read some data sheets, and think about spraying it on a fire. The data sheets recommend applying the paint using airless spray. I have not seen any references to using the liquid paint as a fire stopper, so that would be a good project. This paint is apparently viscous, and the normally recommended airless spray equipment is quite large and expensive. Another possibility is to spray using carbon dioxide as the propellant.
You could try spraying using an engine wash gun. If initial tests look promising, and you need more flow, look into Fox Valve venturi eductors: https://www.foxvalve.com/. I have had good luck with their eductors.
Foam based portable extinguishers (for flammable liquids) do exists already.
I guess that confirms at least the idea itself.
So what remains is to pick the right materials.
The classic 'elephant toothpaste' does not fit.
There are two elephant toothpaste experiments that I am aware of. I think you mean the one using hydrogen peroxide with potassium iodide. The foam produced contains oxygen, which will re-kindle a glowing splint. I tend to think that the foam would promote rather than extinguish a fire.
Likes Occar and Tom.G
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
