Elevator pulled upward by cable - find tension
The discussion focuses on calculating the tension in a cable pulling an elevator upward with a combined mass of 2000 kg. When a coin is dropped inside the cab, it accelerates downward at 8.00 m/s², indicating that the elevator is decelerating. The tension in the cable is derived from the net force equation, where the upward tension is slightly less than the weight of the cab and occupant due to the downward acceleration. The calculation confirms that the tension is 16,000 N, reflecting the elevator's slowing motion. Understanding the relationship between the coin's acceleration and the elevator's movement is key to solving the problem accurately.
shawpeez
here's the question,
An elevator cab is pulled upward by a cable. The cab and its single occupant have a combined mass of 2000kg. When that occupant drops a coin, its acceleration relative to the cab is 8.00m/s^2 downward. What is the tension in the cable?
could someone explane to me how to relate the accerleration of the coin downward to the acceleration of the cab being pulled up.
IF the elevator is going up, and the apparent acceleration in the cab is less than 9.8 m/s/s, then the elevator is at that moment slowing down.
If an object is being pulled up at a constant velocity, then there is zero acceleration because forces are balanced (specifically, the tension in the cable balances the weight). Dropping the coin inside at this moment, the coin would display normal acceleration to the person inside the cab, no matter what speed the elevator was doing.
If the elevator is slowing down, then the upward tension in the cable must be slightly less than the total weight (thereby making net force NOT zero but slightly downward).
So what's the accelration of the cab, if gravitational acceleration "seems to be" 1.8 m/s/s less than normal?
My first instinct was that the upward acceleration of the cab was slowing down, this is what i did
Fnet= T - mg = ma
T - 2000(9.8) = 2000(-1.8)
T - 19600 = -3600
T= 19600 - 3600
T = 16000 N
Is this correct ?
You are correct. Follow that instinct (but don't say "the acceleration was slowing down," it's the speed that is slowing down.)
thanks for the help:smile:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
