I EM wave decomposition to axis components in the Rayleigh-Jeans cube
  • I
  • Thread starter Thread starter aliinuur
    Decomposition
The discussion focuses on the decomposition of electromagnetic (EM) waves into axis components within a Rayleigh-Jeans cube framework. It highlights the relationship between wavelength and integer values for the cube dimensions, specifically noting that λ does not fit as an integer. The wave equation, derived from Maxwell's equations, must be satisfied, with boundary conditions requiring that fields diminish at the edges. The provided formulas for λ_x and λ_y correspond to specific integer values for n_x and n_y. The conversation suggests that a similar approach can be applied directly to three-dimensional cases.
aliinuur
TL;DR Summary
why axis components of the wave must fit as integer, but wave itseld does not?
$$\lambda_x = \frac{L}{n_x} , \lambda_y=\frac{L}{n_y} . \lambda$$
does not fit the cube as integer. In the figure
$$n_x=4, n_y=3$$
I don't know what you mean exactly, but wave equation must be satisfied for the EM wave (Derived from Maxwell's equations). Boundary conditions are that the fields die at the edges, which leaves you exactly with the two formulas that you provided. (You can do for 3d case directly)
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
