EMC Peak vs Average Detection: What's the Difference?
  • Thread starter Thread starter senmeis
    Standard
Military EMC standards like MIL 461 mandate peak detection, while consumer standards typically use average detection. Peak detection is not necessarily stricter but focuses on the highest RF noise levels. The effectiveness of compliance with standards depends on emissions, testing methods, and specific limits. Peak detection serves as a reliable "worst case" screening method, often indicating good performance if it meets average detection levels. This approach allows for targeted work on high emission frequencies identified during testing.
senmeis
Hi,
I’ve read military EMC standard (such as MIL 461) requires peak detection while consumer standard requiers average detection. Does it mean the peak detection is stricter than the average one?
No, but the peaks create the top RF noise.
senmeis said:
Hi,
But... In addition to different spectrum analyzer configurations, the limits required are also different. So whether you meet your applicable standard can depend both on the sort of emissions you have, the test methods, and the limits.
However, in my experience (mostly commercial products), peak detection is a fairly good "worst case" screening setup. It's a quick and easy way to check. If you pass the levels required for averaging detectors with your peak detector, your usually in good shape. Then you can focus your work on the high emission frequencies you see. The average detectors will seldom give more signal than peak detectors.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
