B EMF induced by Bar Magnet falling through a Coil
  • B
  • Thread starter Thread starter neilparker62
The discussion centers on the induced electromotive force (emf) when a short bar magnet falls through a long coil, with the north pole entering first. As the magnet approaches, a north pole is induced in the coil, and upon exiting, a south pole is induced, resulting in a graph with positive and negative peaks. The conversation highlights that the peaks may not be symmetric due to the magnet's varying speed during entry and exit, with zero emf occurring while the magnet is fully within the coil. An article referenced confirms that the difference in peak amplitude is theoretically related to the transit time of the magnet through the coil. Overall, the dynamics of the induced emf during the magnet's movement present interesting implications for experimental investigation.
neilparker62
Insights Author
TL;DR Summary
Induction, Lenz's law
What should a graph of induced emf look like if you have a relatively short bar magnet falling through a long coil ? Let's say the north pole is first to enter. So as it approaches a North pole will be induced in the coil which then looks like a N-S bar magnet. When the magnet exits , the south pole leaves last so at that point a North pole will be induced at the other end of the coil which now ends up like a S-N bar magnet. So overall the emf should have a positive peak and then a negative peak or vv. I'm not quite sure what happens in between. Are the two peaks symmetric or does the graph have some asymmetry due to the bar magnet slowing down on entry and speeding up on exit ? Is there a constant emf for the time during which the bar magnet is totally surrounded by the coil ?
Edit: found an answer here:
for anyone else who might have wondered.
I explored the magnet falling through a solenoid in the limit of a very short bar magnet, i.e. a point dipole, in this article. Your conjectures are correct. In between the emf is zero and yes, there is an asymmetry in the peaks due to the increased speed of the dipole. The difference in peak amplitude is (theoretically) proportional to the transit time of the dipole through the solenoid (equation (5) in the article.) I do not know if this asymmetry has been investigated experimentally.
Likes neilparker62 and berkeman
Great article - it will take me some time to digest the Maths but the graphs show clearly what is happening 'in transit'.
Likes berkeman and kuruman
Thank you for your interest. You might also consider reading the related article of how to model a magnet falling through a conducting pipe, a well known classroom demonstration.
Likes davenn and berkeman
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
